Old 09-28-2008, 02:57 PM   eBay Motors   #11 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
that is what I am afraid of, a bent rim can cause some serious issues when hauling those weights... like braking welds and coming apart going down the road...
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
Old 09-28-2008, 03:29 PM   eBay Motors   #12 (permalink)
MacRebel
MacRebel's Avatar
If you're shocks are worn, that could also be the issue. If the stiffness of your suspension starts to drop, it will change the natural frequency of the system and therefore change the rpm at which you will feel a lot of vibration. So if the tires and rims checkout okay, I'd immediately replace the shocks.
2008 Silverado 2500HD LTZ
6.6L Diesel (LMM), CrewCab, Shortbed Z71
4" MBRP Exhaust with 5" tip (DPF deleted & EGR blocked), Quadzilla Stealth 2, Autometer Cobalt Boost and EGT gauges on the pillar, Cognito leveling kit with BFG A/T 285's on XD Series 18's, 15% window tint with vent visors, TruckChamp black bars, Extang Tonneau cover.....
and more to come hopefully..... like tow mirrors, Line-X bedliner, and a CAI...
MacRebel is offline   Reply With Quote
Old 09-28-2008, 03:44 PM   eBay Motors   #13 (permalink)
Blues
Blues's Avatar
I agree. These trucks have a problem that begins when you change the angle of the rear diff. This causes the u-joints to be at different angle on the driveshaft (hence the vibration). Also, pull the shaft and check for a "dry" cup on any of the u-joints. (P.S. Did you have an empty box or a little weight on board?)
2005 GMC SRW 1 ton ex. cab. Edge EZ box for extra 65 HP and 200 Ft/lb torque. (just what I needed!):tease
Looks FAST!!!!! 110 MPH even when it's parked (due to a stuck speedo)
Blues is offline   Reply With Quote
Old 09-28-2008, 04:35 PM   eBay Motors   #14 (permalink)
bigdaddydiesel
it was empty, all it had on it was a soft cover that came on the truck...
but that all makes sense, I think I will just replace all of the suspension components and be done with it...that should do it...
ie: shocks, bushings, tires, rims, etc...
Chris Kelley
Email
1-888-563-5143
Old 09-28-2008, 05:36 PM   eBay Motors   #15 (permalink)
MacRebel
MacRebel's Avatar
yeah, that's one way to do it. unfortunately, if it doesn't work, you spent a bunch of money and have no idea where to go from there. good luck.
Old 09-28-2008, 06:22 PM   eBay Motors   #16 (permalink)
bigdaddydiesel
I will do each one at a time to make sure that I can tell if I fix this particular problem, but I would be replacing most of this anyway, with 166k on the stock stuff, it is time for new all around anyway...IMO
Chris Kelley
Email
1-888-563-5143
