major white smoke - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 10-02-2008, 06:49 PM Thread Starter
major white smoke
I have an 03' with a banks tuner, and a 5" exhaust, everything else is stock. I have had a little white smoke for sometime and was told it could be an injecture. But recently it has started smoking really bad with a tick in the motor and was told that it was a fuel knock meaning the injectures are bad. but i have smoke coming out a hose in the front of the motor near the bottom i have chased it to both valve covers. It is putting out smoke constanly. I dont have any fuel in the oil though. Does any one have any idea what might be going on. Thanks
Duramax457 is offline
post #2 of 15 (permalink) Old 10-02-2008, 10:25 PM
Tow Master's Avatar
Welcome to the forum!
Usually white smoke means either head gaskets or injectors. It could be pushing to much fuel into the cylinders. Did you change the fuel filter lately? Gonna be hard to diagnose. You might have take it in to the shop!
Jason
Tow Master is offline
post #3 of 15 (permalink) Old 10-06-2008, 09:21 PM Thread Starter
yea i changed the filter what puzzles me is why the smoke is coming out the vent tube
post #4 of 15 (permalink) Old 10-06-2008, 10:13 PM
Durallymax's Avatar
They do weird things when the injectors go out. ach truck is different. If you dont smell coolant take it to the dealer for injector replacement.
Does it start hard??
Durallymax is offline
post #5 of 15 (permalink) Old 10-07-2008, 03:58 PM
jaydawg's Avatar
Possible blown piston, rings???
jaydawg is offline
post #6 of 15 (permalink) Old 10-08-2008, 06:31 AM Thread Starter
it actually starts easy i have it scheduled for the injecture swap. i hope that solves it. if it does need rebuilt does antone know of some aftermarket companys selling rebuild kits. if i got to rebiuld it i might as well beef it up. Thanks
post #7 of 15 (permalink) Old 10-08-2008, 03:53 PM
jaydawg's Avatar
Take off all programmers before going to dealer!!!!!!!!
jaydawg is offline
post #8 of 15 (permalink) Old 10-08-2008, 07:31 PM
Durallymax's Avatar
^^^ unless you have a cool dealer like mine.
So you wanna beef up your LB7.
Well heres a few numbers to toss around. These are from my buildup.
Mahle Pistons w/remachined bowls, thermal coating and lubricty coating:$2,300
Carrillo Rods $3,125. There are cheaper rods though too. The cheapest being about $2,400
Billet Main Caps $600
Billet Injector Clamps $400
Injector Studs $180
Head studs $660
ATI Super Damper $440
Banks Flex Plate $??
and then all of the seals, the new water pump, the new oil pumps, and all of the machine work.
It aint cheap to beef up a duramax.
post #9 of 15 (permalink) Old 10-10-2008, 05:01 PM Thread Starter
Well we just recently done a compression test and #7 cylinder failed. So time for a rebuild. I have a banks tuner now am gonna sell it and beef my motor but am looking for the right tuner any suggestions? PPE hot 2 is what i am looking at. Also looking for suggestions on tranny mods any info would be appreciated? Thanks
post #10 of 15 (permalink) Old 10-10-2008, 07:19 PM
D.W.'s Avatar
If you have a ticking noise then it is likely an injector, how many miles are on your truck?
2005 Chevrolet 2500HD crewcab LLY, LT3 package
Banks 4" Monster Exhaust, S&B cold air intake, Kodiak mouthpiece and MBRP cat delete pipe
Recon "Line of Fire" LED tailgate Bar
B&W turnover ball, Pac-brake air springs
BF Goodrich All-Terrains 285/75/R16 on stock rims
Mods to come:congnito tie rods, and PPE Excellerater Standard
Other Ride: AKA the commute car
1993 Ford Probe
Broken headlight that stays up, primer grey hood:rockin
D.W. is offline
