intake heater malfunction and glow plug codes!q - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 10-24-2011, 06:44 AM Thread Starter
Exclamation intake heater malfunction and glow plug codes!q
I have an 02 gmc duramax, federal emissions. I have been chasing the SES light for a while now, it has to do with the intake heater and the glow plugs. I changed both relays with the napa ones that I got the part number to off here. The problem is still happening and the same codes are being thrown. I think it might have had a program in it before I bought it and the owner took the monitor out but never flashed it back to stock. I am thinking the program did something to the intake heater, maybe shut it off? Therefore making the glow plug code go off since it is all one circuit. I had a computer plugged onto the truck and when the key was turned on it said the glow plugs were on but no power to them. I am very confused and don't know if I need to turn the intake heater back on and that will fix the prob or what. Also after a long trip it seems to turn over more to start. The guy also replaced some glow plugs before I bought it
dmaxhardy is offline
post #2 of 7 (permalink) Old 11-24-2011, 05:55 PM
Do these trucks have intake heaters? I know for sure the cummins have the intake heater but thought the duramax only had the glow plugs...correct me if im wrong.
rabbit81 is offline
post #3 of 7 (permalink) Old 11-26-2011, 10:19 AM
VulcanD3's Avatar
Yes they do, I have an 02 and it has been throwing the p0540, intake air heater circuit code for a while now. There is a thread on here showing the location. There is a large fuse under the front of the fuse housing cover in the engine compartment. It is a 175 amp fuse. There is also a relay on top of the engine somewhere under the 6.6 plastic cover. My fuse was ok so I suspect the relay or the heater itself. Since it doesn't start hard it has not been a big priority for me. Search error code p0540.
2002 2500HD Crewcab LT short bed, no mods.
VulcanD3 is offline
post #4 of 7 (permalink) Old 11-26-2011, 01:00 PM
moochoff's Avatar
Do you even need the plugs to work if your grid heater is operational?
'06 Megacab 4x4- tow rig
'98 1500 4bt Cummins- MPG rig
'98 s10- soon to be raced with #2
moochoff is offline
post #5 of 7 (permalink) Old 11-26-2011, 02:42 PM
VulcanD3's Avatar
I would think the glow plugs would be more important then the air heater but I really don't know.
VulcanD3 is offline
post #6 of 7 (permalink) Old 11-26-2011, 05:43 PM
moochoff's Avatar
New to Dmax, but I only made that assumption because the cummins runs just the grid heater and no glow plugs...
moochoff is offline
post #7 of 7 (permalink) Old 01-04-2012, 01:33 PM
dmax's don't have a grid heater like the cummins. The intake air heater is just a probe that screws in the intake pipe.
kemp2011 is offline
