2003 Sierra died while driving and wont start back - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 11-22-2011, 02:11 PM Thread Starter
Pipe Welder's Avatar
Hey guys i was driving my truck and it just quit. No smoke, no missing, no rough running.. just stopped like the key was turned off. Cranks over fine but will not start. Please help I have my welding equipment in the bed and need it running so I can work.
2003 GMC Sierra 2500HD, Superchips programmer, 5 inch MBRP exhaust deleted cat, boost valve, 6 inch lift, 315/75/16's on M/T wheels
Pipe Welder is offline
post #2 of 4 (permalink) Old 11-22-2011, 02:16 PM
ATS Diesel Performance
lb7blksmk's Avatar
Send a message via Yahoo to lb7blksmk
sounds like you got air in your lines, make sure you have over a 1/4 tank and reprime the truck and check for leaks.
David Spidle
03 LB7Auroura 5000 W/ Manifolds & Up-pipes, Synapse 50mm Gate, 40% Over Injectors, Alligator Stg5 Trans, EFI Live
lb7blksmk is offline
post #3 of 4 (permalink) Old 11-22-2011, 06:13 PM
Administrator
jc1843's Avatar
I suggest you add 5 gallons of diesel-- the gauges are sometimes off-- also I have heard of the pick-up straw breaking and sucking air, instead of fuel.
Pump the primer on the filter housing-- and open the bleeder to see if there is fuel. If you ran out of fuel, you will have to pump and crank, pump and crank-- repeat
You should also check for codes-- a cheap reader may be a good investment.
Crank position sensor-? Can be a number of things-- but start with the suggestions.
jc1843 is offline
post #4 of 4 (permalink) Old 12-09-2011, 04:25 PM
Mine was doing the samething i checked my wiring harness for the fuel control module that runs on top of the alternator there was a short in it causing my truck to shut down without any warning. The bracket that runs along the alternator has a sharp corner cutting into the wires. Just another place to check.
2002 GMC Sierra 2500HD 4x4 crew cab. 6.6 duramax with 205,000 miles. Bullydog Monitor. K&N cold air intake. 5 switch EFI live. Bosch Injectors. Air dog fuel system set 8 psi. PPE boost valve, 33" AT Tires, Lifted 3 inches, Rebuilt Allison Tranny HD, Transgo Shift Kit, Triple Disc Torque Converter.
firefighter150 is offline
