Engine has a missing problem - Chevy and GMC Duramax Diesel Forum
post #1 of 22 (permalink) Old 11-28-2011, 08:58 AM Thread Starter
I have an 04 LB7 with 75,000 miles.
The engine will randomly miss, it doesn't matter if the engine is hot or cold. Sometimes it will do it while its idling. Sometimes I can drive around for 30 minutes and it won't happen at all.
There have been times where, I almost had to pull off the side of the road because it was bad.
Its almost like the engine is completely shut off for a second.
Any ideas?
nhraracer90 is offline
post #2 of 22 (permalink) Old 11-28-2011, 09:46 AM
DirtyMaxx03's Avatar
codes?
Sean
2003 Lb7 2wd
Dropped
Efi Live by Rob Coddens
s472
DirtyMaxx03 is offline
post #3 of 22 (permalink) Old 11-28-2011, 12:44 PM Thread Starter
No codes. Nothing comes up in the DIC. I was going up the interstate today and it was missing pretty bad.
post #4 of 22 (permalink) Old 11-28-2011, 12:49 PM
I STILL DGAF
Duraskank's Avatar
How long has this been happening?
GW: 2005 CHEVROLET LT CCSB LLY 4WD|SOLD|SkankLilly
2006 GMC SLT ECSB LBZ 4WD -SOLD skankmobile2dot0 Pics
2007 CHEVROLET LS CCSB LBZ 4WD|June ROTM 2011 - SOLD|Dmax Pics
07.5 CHEVROLET LT2 CCSB LMM 4WD|SOLD|LMM 'build' thread|LMM pics
2011 GMC RCLB LML 4WD @duraskank
Duraskank is offline
post #5 of 22 (permalink) Old 11-28-2011, 12:50 PM
born country
Dmaxryan10's Avatar
injectors?
have you checked the balance rates yet?
could be an injector taking a dump.
NEW TRUCK- 2006 LBZ cc/sb loaded southern coach, smoky mountain sportsman edition, 20" black hostile havoc's, 305/50/20 nitto trail grapplers, EFI LIVE by rob at ATP performance, 5" exhaust, transgo jr, egr blocked, pcv rerouted, isspro ev2 gauges, tinted windows, just gettin started!
Dmaxryan10 is offline
post #6 of 22 (permalink) Old 11-28-2011, 03:35 PM Thread Starter
A few months but I have only driven it daily the last 2 weeks. I believe it is getting worse.
Would an injector going bad make it miss like it does? Sometimes I can drive around for 30 minutes and it wont do it. Would one injector going bad make it miss like the engine is shutting off for a split second?
How do I check the balance rates? Does it need to go to a dealership with a tech 2?
post #7 of 22 (permalink) Old 11-28-2011, 04:26 PM Thread Starter
I hooked up my MicroScanner and I found the following codes:
These codes were in history : P0380 and P0381
I know that the P0381 is the Glow Plug indicator on the dash but I do not have any problem with that coming on or going off, so I don't know why that code is in history.
The P0380 is the Glow plug heater circuit A malfunction i believe? What is that?
Also in the ABS, I found these codes : C0035, C0040 and C0055.
The check engine light is not coming on nor are any of the other dash lights, so I am unsure why these are on.
post #8 of 22 (permalink) Old 11-28-2011, 04:29 PM
born country
Dmaxryan10's Avatar
you could start by replacing your glow plugs.
is your truck federal emmissions or cali?
it could be your glow plug controller took a dump on you.
post #9 of 22 (permalink) Old 11-28-2011, 04:31 PM
I STILL DGAF
Duraskank's Avatar
Yeah you need to take it in. Dealer can read balance rates, or someone with a V2 if you know anyone.
post #10 of 22 (permalink) Old 11-28-2011, 04:36 PM Thread Starter
No it is not Cali or federal emissions.
Im not having any trouble starting the truck cold or anything. Would bad glow plugs make the truck miss even when its warm?
