Fuel Pressure Regulator - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 01-09-2012, 05:16 PM Thread Starter
rebpdt's Avatar
So I've been playing with all the PID's on my insight. Set my DFRP and FRP to watch for a while. Did these bc my truck lopes to a stop when it cold like crazy and still does it to a lesser degree when it's warm. I know it's not my AD - Hooked a gauge up - 8 psi...
Anyways when my truck is cold and on startup it calls for 6200 psi DFRP actual is the same. As it warms up it will get down to 4900 desired and actual.
I do not have elevated or high idle - is it normal to be up at 6200 on startup?
When I come to a stop it lopes as i said earlier. They actual stays much higher than the desired when coming to a stop or going down hill.
Checked DTC codes - p0089 fuel pressure regulator - duh....
Along with the code, are these signs that it's going out???
It's not surging at idle, or bucking around...
And the injectors are fine - did them in November
CCSB LB7 4x4
rebpdt is offline
post #2 of 10 (permalink) Old 01-09-2012, 08:00 PM Thread Starter
rebpdt's Avatar
CCSB LB7 4x4
rebpdt is offline
post #3 of 10 (permalink) Old 01-09-2012, 08:12 PM
Mine does the same at startup.
Jason
2005 Chevy 2500HD LLY CCSB
EFI Live DSP5 by Idaho Rob, Pillar Mount CTS
AFE MP, MBRP 4" Straight Pipe, EGR Delete
Magnaflow DP, LB7 Up Pipe, ARP Head Studs
PCV Reroute, Resonator Block, Shimmed/Ported
Donaldson Filters, Bars Cranked, Debadged
Bilstein 5100's, Rancho 5000 Stabilizer
Gooseneck Hitch, 285's
Sold: 2003 Silverado SS 6.0L AWD
Jkam0365 is offline
post #4 of 10 (permalink) Old 01-10-2012, 05:40 AM Thread Starter
rebpdt's Avatar
Bump for the morning crowd...
Should my actual FRP remain higher than my desired when coming to a stop or going down hill?? Is this my fuel pressure regulator going out, based on this and the above?
CCSB LB7 4x4
rebpdt is offline
post #5 of 10 (permalink) Old 01-10-2012, 06:34 AM
Banned
Sticking FPR replace it, it will just get worse.................
smokinlmm is offline
post #6 of 10 (permalink) Old 01-10-2012, 06:40 AM Thread Starter
rebpdt's Avatar
Thank you sir. Basically what I thought, just wanted someone smarter than me to tell me
Looked it up on alldata- do ALL those connections really have to be unplugged? Some tod them aren't even close to the valley...
CCSB LB7 4x4
rebpdt is offline
post #7 of 10 (permalink) Old 01-10-2012, 06:52 AM
Banned
I just unplugg what ever is in the way............
Just make sure to unhook both your batteries before starting.............
It is really not that hard, the torques on the FPR are the worst part of it. I made an extended bit to help out a bit and had a buch of swivel and wobble extensions...........
post #8 of 10 (permalink) Old 01-10-2012, 07:05 AM Thread Starter
rebpdt's Avatar
Good deal. That's usually what I do, but this one just seemed odd w all the connections listed to unplug. Thought id check. Now I just hope the part store has one as diesel anything is what they are always out of inventory on.
Might have to order one w my luck...
CCSB LB7 4x4
rebpdt is offline
post #9 of 10 (permalink) Old 01-10-2012, 07:15 AM
Banned
Merchant has them for a decent deal.............
Had the last one from them in 2 days.................
post #10 of 10 (permalink) Old 01-10-2012, 07:21 AM Thread Starter
rebpdt's Avatar
Yeah they're always quick. Got my fuel rail lines in 3 days last month and one was a Saturday
CCSB LB7 4x4
rebpdt is offline
