2001 oil cooler O-rings leaking - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 01-17-2012, 07:40 PM Thread Starter
Bransjeep's Avatar
Hey guys ive a question about my friends 2001 LB7, it has leaking oil cooler o-rings and i need to locate the oil cooler and where its leaking..so have any of you guys repaired this or know where ill find this in the engine bay? i havent looked at it yet but will be tommorow. so im looking for a little info before i takle this
Thanks
Brandon
Black 04 LLY 6" Tuff Country EZ Ride. 35-12.50 20 Trail Graps, Moto Metal 955, Bilstein 5100's. AMP powerstep. 4" MBRP Turbo Back w/5" tip. pcv re-route, LBZ inlet and S&B, EFI Live! DSP5 powered by Edge insight CTS...EGR blocked. Viper remote start and alarm. Custom built bumper by CountryBoy2500, with 3000k HID's and Hella 500's. 5000k HID's in lows. Raptor lined rocker panels. Tinted to match and tow mirrors. Energy Suspension Poly bushings. Kenwood ddx371, 9 speaker J&L audio setup. LML manifold. Air Lift bags, 35 Gallon TransferFlow Tool box combo.
Bransjeep is offline
post #2 of 6 (permalink) Old 01-17-2012, 07:47 PM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
the oil cooler is part of the oil filter housing.
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
post #3 of 6 (permalink) Old 01-17-2012, 07:50 PM Thread Starter
Bransjeep's Avatar
ok. so when these leak are there several? just one? eaasy to get to?
post #4 of 6 (permalink) Old 01-17-2012, 08:26 PM
Im Superrrrr!
jmaz268's Avatar
its pretty confined back there.
Goes by John
--2001 ECSB
--2005 CCLB Dually
The tow pig
jmaz268 is offline
post #5 of 6 (permalink) Old 02-10-2012, 08:55 PM
FordTechChase's Avatar
There is a TSB for this. Mine also leaks here. I went to my dealers sister store and the GM techs acted like they had never heard of this issue. TSB is number 02-06-01-023F. Looks like replace the orings and apply some grey sealer to the orings before install.
Warranty pays 1.5 so even at customer pay rates thats only 2.1. It shouldn't be that big of a deal. Looks like take the filter off then the bolts for the cooler to the coolant pipe. Then the bolts to the block. Hoping to tackle this and the water pump next week on mine. May also replace the bad glow plugs since I will have it tore apart some.
FordTechChase is offline
post #6 of 6 (permalink) Old 06-23-2012, 05:00 PM
Gregaz's Avatar
Did you ever get this fixed, mine is leaking for the top o-ring and I am decideding if I am going to nut up and do myself or if it's cheaper/less headache to pay.
Gregaz is offline
