Help! Truck won't rev over 2000 rpm - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 01-25-2012, 01:34 PM Thread Starter
Jay146992's Avatar
So I was driving home and my truck started slowing down and wouldnt rev over 2000 rpm and won't up shift. Temp is fine and so is everything else. What is wrong with my truck? I have a PPE tune level 2.
2005 Chevrolet Silverado LT 3500 4x4 Dually. EFIlive DSP5, AFE Mouth Piece, S&B Intake, ARP Head Studs, Airdog 165, Nicktane Adapter with Cat R1-7049 Filter, MBRP Down pipe, MBRP 4" Exhaust, High Flow Manifold, PCV Rerouted, EGR Deleted.
2015 GMC Sierra 2500HD CCSB SLT 4X4 Fully Deleted. MBRP Downpipe, 5" Turbo back Exhaust, efilive tuning by Motor Opts, S&B Intake, Airdog 4g Lift Pump, Cognito 12" stage 2 lift, 24x14 Hostile wheels, 40x15.50 Trail Grapplers, RBP Grill.
Jay146992 is offline
post #2 of 20 (permalink) Old 01-25-2012, 01:38 PM
rebpdt's Avatar
Any codes ,CEL's?
sounds like you limped your tranny...
what level were you on when you romped on it
turn your tuner down
CCSB LB7 4x4
rebpdt is offline
post #3 of 20 (permalink) Old 01-25-2012, 01:44 PM
suttert's Avatar
yeah you limped her, put your ppe on there, tune it down a level and clear codes. when you turn her back on, she should be fine. If there's no code or all what i said earlier didnt help any, you might have a nsbu problem. but lets see what happens before we go that far...
Trey
01 gmc sierra slt crew cab 4x4 6.6 dmax, efi live by Idaho Rob,
315/75/16 Goodyear Duratracs on 16" Moto Metals,
3" body lift, 5" Diamond Eye straight pipe with 7" tip,
Z Series Autometer Boost and Pyro, 6k Highs 8k Lows and 3K fogs, tinted windows
cat adapter and donaldson filter, adII
horn intake mod, tinted tails, lots of plasti dip
led interior and dash lights, retros led reverse lights
Big thanks to ATP TRUCKS and ALLIGATOR PERFORMANCE
suttert is offline
post #4 of 20 (permalink) Old 01-25-2012, 01:47 PM Thread Starter
Jay146992's Avatar
Originally Posted by rebpdt View Post
Any codes ,CEL's?
No codes no lights nothing. I was driving down the highway at 65 when it happened. I didn't gun it at all today, I was just driving home from work on level 2.
post #5 of 20 (permalink) Old 01-25-2012, 01:49 PM
rebpdt's Avatar
when was the last time you changed your fuel filter?
and scan it anyways to make sure you dont have any codes - your CEL may not work
CCSB LB7 4x4
rebpdt is offline
post #6 of 20 (permalink) Old 01-25-2012, 02:05 PM Thread Starter
Jay146992's Avatar
The fuel filter was changed 2000 miles ago. Just scanned it and there are no codes.
post #7 of 20 (permalink) Old 01-25-2012, 02:08 PM
rebpdt's Avatar
does your gear select cluster light up?
CCSB LB7 4x4
rebpdt is offline
post #8 of 20 (permalink) Old 01-25-2012, 02:12 PM Thread Starter
Jay146992's Avatar
Yes it does. Everything works and looks normal as far as tell. The truck will start right up but just won't rev over 2k. Actually it stops at like 1800 rpm
post #9 of 20 (permalink) Old 01-25-2012, 02:20 PM
rebpdt's Avatar
change your fluid recently?
spin on filter?
look for leaks?
check the fluid level?
CCSB LB7 4x4
rebpdt is offline
post #10 of 20 (permalink) Old 01-25-2012, 02:46 PM
Administrator
jc1843's Avatar
Start with a new fuel filter-- if the trans is in Limp mode-- it will set a code.
jc1843 is offline
