| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 01-04.5 LB7 Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
09-16-2007, 03:01 PM
eBay Motors
#11 (permalink)
| | Member
| When I asked about the injector pump being warranted for 5 years they told me it wasn't. They also told me that the injectors weren't warranted to 200,000 miles......I am really getting tired of all the BS I have been getting from the dealers. |
| Advertisement
09-16-2007, 05:20 PM
eBay Motors
#12 (permalink)
| | Junior Member
| Bulletins for Fuel Injectors Good Afternoon,
The bulletin I have is labeled Document ID#1866141
Which quotes;
Models 2001-2003 Chevrolet Silverado
2001-2003 GMC nSierra
2003 Chevrolet Kodiak
2003 GMC Topkick
Equipped with 6.6 L Duramax Diesel (RPO LB7-VIN Code 1) Engine
If you have any further questions you can e-mail me directly
at O2beclean@aol.com
Hopefully your trucks claim to fame will not be like mine " 88,000 miles and four sets of injectors later!"
Good Luck
Lawrie |
09-16-2007, 06:19 PM
eBay Motors
#13 (permalink)
| | Member
| Where can I find that Bulletin? |
09-16-2007, 07:20 PM
eBay Motors
#14 (permalink)
| | Junior Member
| Injector bulletin You can probably ask your local dealer, and they should have it on hand. If not let me know and I can either E-mail you a copy of it in an adobe file tomorrow or I can fax it to you if you give me a fax number!
Lawrie O2beclean@aol.com |
11-16-2007, 10:08 PM
eBay Motors
#15 (permalink)
| | Duramax Forum Supporter
| has anyone else had a problem where you have a really rough idle. i know diesels can be rough, but this is like massage chair vibrating. it goes away once i have it in gear. could this be an injector problem? i havent noticed extra diesel in my crank case. any suggestions wlecome
__________________ 02' bowtie 2500HD CC SB LB7 ZF 6-speed
autometer cobalt gauges. MTX components front, coaxials rear. recon strobes. cobra 29LTD chrome w/pa spkr. S&B intake southbend clutch and flywheel
PPE standard in the mail!!
Brotherhood of handshakers member #130
Real men wear bow ties! |
11-18-2007, 04:47 AM
eBay Motors
#16 (permalink)
| | Junior Member
| Quote:
Originally Posted by crazy LB7 has anyone else had a problem where you have a really rough idle. i know diesels can be rough, but this is like massage chair vibrating. it goes away once i have it in gear. could this be an injector problem? i havent noticed extra diesel in my crank case. any suggestions wlecome | you do have injector issues if you find fuel in the crankcase, poor idle, smoking at idle, and for everyones info injectors are covered up to7 yeras & 200k miles for 01-03 LB7's. Another policy supports the same thing but if they even think or see evidence of a tuner no warranty and they will black flag the VIN
__________________ 2004 GMC SLT LB7 CC Shortbed with Ranchhand Grill Guard; 195k+ miles
4 KC off road light, Century Topper
Hammer 4 Train Horns and Conductors Special at 150psi ; Westin Nurf Bars HypertechIII Powered 6.6 Dmax; Amsoil bypass filters & Amsoil in oil and tranny;Nicktane Fuel Filter, Scangauge II,Fumoto Valve, Active XM and Onstar,Protected by Viper
2002 Chevy Suburban
1996 GMC Jimmy SLT
US Army Veteran 25 Years of Service
If this great nation cannot summon the will, the determination and the fortitude to persevere, then we shall forever be damned by the heroic dead who gave their last full measure of devotion; by all those who served & sacrificed in this noble cause. |
11-27-2007, 08:10 PM
eBay Motors
#17 (permalink)
| | Junior Member
| Well the saga goes on. GM replaced My injectors with new and improved, gauranteed not to leak into the crankcase. Two days after getting My truck back one of the injectors failed and resulted in a heavy white smoke bellowing from under the hood and of course smelled like deisel fuel. They fixed this with another four day stay at the dealer.
After four months and after the five year warranty had ran out My truck started running very rough, like it was running on 7 cylinders. Back to GM for repair. This time it had a bad valve guide and wasn't allowing one of the four valves in number eight cylinder to not seat, causing it not to have compression. GM said it had nothing to do with the six gallons of deisel I had previously in the crankcase. GM wouldn't replace the guide and agreed to split the cost of replacing the whole head with Me, total cost was just over $3,000 dollars. This engine has four valves per cylinder, thus four valve guides per cylinder an only one failed, waiting on the other side to fail now. Truck was in the shop for three weeks. Two days after getting it back went to start it and it would start and run about ten seconds and then shutdown, like someone had turned the fuel off. Raised the hood and pumped the filter till it wouldn't pump anymore and it started. If the trucks sits for three hours it has to be pumped before it will continue to run. Back to GM, they don't have a clue what is wrong this time, some kind of leak in the fuel system. Still didn't have 100,000 miles on engine.
Very Very unhappy with My Chevrolet Duramax that was supposed to be built "Like A Rock" |
12-02-2007, 10:32 AM
eBay Motors
#18 (permalink)
| | Member
| Quote:
Very Very unhappy with My Chevrolet Duramax that was supposed to be built "Like A Rock" | Don't blame the truck for this. Blame the mechanic that did something wrong.
__________________ 2002 2500HD Crew LB Ally 4x4
5" MBRP Edge w/ Att. |
07-23-2008, 11:17 AM
eBay Motors
#19 (permalink)
| | Junior Member
| hey,i,m having a problem with my truck and i took it in with only 20,000 miles on it and the dealer says in need new injectors and possiable a injection pump at a cost to me for $8,000 says i have something in the fuel that does smell funny,they drain the tank put in fresh fuel still have problem.i m in the process of getting new injectors , but if the is something in writing or special that needs to be said to dealer to have them warranty my truck tell me??? |
| Advertisement
