Engine Temp - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 11-14-2008, 04:37 PM Thread Starter
St.Somewhere's Avatar
Question Engine Temp
Is it me or does it usally take a long time for the engine to warm up on a cold morning? A friend told me this is normal for diesels. I'm thinking I have a stuck open thermostat. Its several miles later after heading out in the morning before my temp hand even moves or I have any heat.
Is this normal? Or do I need to replace the thermostat?
2003 Silverado 2500HD LB7 4X4
2007 GMC Yukon Denali 6.2-liter ...Wife's
St.Somewhere is offline
post #2 of 8 (permalink) Old 11-14-2008, 05:24 PM
Received a Hummer
n0useforaname's Avatar
I know for myself....my truck normally starts around 40-50 degrees. I let it warm up for about 10 minutes and it only goes to maybe 80...then after I drive it for 2-3 miles...it goes to like 120... I don't know if that helps....but it does normally take a bit.
Officially sold the truck But bought an H2 that is getting a Dmax
n0useforaname is offline
post #3 of 8 (permalink) Old 11-14-2008, 05:27 PM
Duramax Forum Moderator
DuramaxOnTheBrain's Avatar
The 02 doesn't have the high idle setting does it? Does it require a kit?
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline
post #4 of 8 (permalink) Old 11-14-2008, 05:30 PM
Ridin'GMC's Avatar
it does take a while, diesel engines have more cooling fluid than gas engine does. thats why it takes a while. it also has 2 thermostats to regulate the cooling system. its normal for a diesel engine to take a while to warm up. you can use your block heater to help it warm up quicker if you have one equipped in your truck. most truckers use block heaters to keep their engine warm for quicker starts and warmups in cold mornings.
06 LLY CCSB
Just another white truck on the site
Stock engine and trans.
Ridin'GMC is offline
post #5 of 8 (permalink) Old 11-14-2008, 08:08 PM Thread Starter
Thanks for the info. I didn't know there was 2 thermostats... Seems like I'm learning something new everyday.
post #6 of 8 (permalink) Old 11-14-2008, 10:20 PM
Its normal, They take a long time to get to temp. Dont worry about it.
Toypuller is offline
post #7 of 8 (permalink) Old 11-15-2008, 10:53 AM
VAGITARIAN :)
daddysLBZ's Avatar
Smile My cab is cold until a 160 temp or warmer......
I can idle it for 20 minutes at 45 degrees and the water temp is still under 130*,just the way it is..You'd know about a stuck opened therm too,you would not get any heat in the cab after they usually warm up...Meaning[if therm stuck open,then no way for it to retain the temp then open,just may get to about 160*[if you lucky]and stay there]My truck will NOT blow ANY air into the cab until it's about 150-160,heard it is to keep cold air out cab until it can put heat into there to keep cabin warm..
when engineers get to sniffing glue huh??
2006 GMC 4x4 CC/SB/sle1/LBZ**312,000 miles!!** PPE HOT+2 225 TUNE beeeyotch:-)AutoMeter egt/boost Suncoast 5 trans w/1056TC!tsktsk,billet in/out shafts/MagHytec pan!!,M/A built T-Case,4 in.str8piped,5%tint all around......
2007 Chevrolet 4x4 cc\sb,lbz.......SOLD to blunova
Also, I speed and don't come to complete stops at stop signs.
''don't sweat the petty things,pet the sweaty things''
Click below/pictures of my junk!!
http://www.duramaxforum.com/forum/vb...do=hall&u=8415
daddysLBZ is offline
post #8 of 8 (permalink) Old 11-15-2008, 12:06 PM
dmax500's Avatar
far as i know the 02 lb7 do it will only turn on after its about 10 below or somewhere close to that cant remember exactly what temp. if you want to add a comandable high idle check out ppe's high idle kit.
2001-2005 High Idle Valet Switch - $59.99 : Pacific Performance Engineering, Innovations in Diesel Performance
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's exhaust,ARP headstuds.
dmax500 is offline
