2001 lb7 oil from crankcase vent - Chevy and GMC Duramax Diesel Forum
post #1 of 40 (permalink) Old 02-19-2012, 01:27 PM Thread Starter
whitey09's Avatar
Hi everyone, I've been searching and I know there's already threads on this but they dont seem to match what mine is doing. I just purchased this truck last week, my first diesel. It has 132000 miles. It has new injectors put in a few months ago. I was under it last night trying to rip off my brake backing plate that decided to fall off 100 miles from home and i noticed oil coming from the crankcase vent that has been leaking and running back. I don't remember the leak being there when I looked at the truck. The oil does not smell like fuel and the truck seems to run perfect. But when I checked the dipstick after sitting overnight it seems overfull. Where do i start with this? An oil change and monitor the level? Is there something that can be cleaned that could be plugged causing excessive pressure? Any input is greatly appreciateted, I'm getting more and more frustrated with this truck
2001 Chevy 2500HD LB7 ECSB 4x4
110hp EFI live Tune
PPE Boost Valve
5" Diamond Eye Exhaust
whitey09 is offline
post #2 of 40 (permalink) Old 02-19-2012, 01:41 PM
start wil an oil change and keep an eye on the level better to feel the oil between finger and thumb to see if there is fuel in it than smell it can be hard to smell pcv valve mabe could be excessive blow by
trevrosborough is offline
post #3 of 40 (permalink) Old 02-19-2012, 01:54 PM
DuramaxForum Guru
kman2468's Avatar
Send a message via AIM to kman2468
Pull dipstick out and put drop of oil on paper towel. Does a ring form around the oil?
Kyle
13 lml stock
sold 04.5 lly
kman2468 is offline
post #4 of 40 (permalink) Old 02-19-2012, 03:33 PM Thread Starter
whitey09's Avatar
I dont think so, but heres a pic
and here is a pic of the leak
what do you think?
110hp EFI live Tune
PPE Boost Valve
whitey09 is offline
post #5 of 40 (permalink) Old 02-19-2012, 03:54 PM
DuramaxHD10's Avatar
Mine was doing the same thing when it make making oil....
You best bet is to drain the oil and see how much comes out. You should get 10QTS of oil.
You'll need more oil on the paper towel to see if its making oil.
2005 CC SB LLY-Air dog 165 Factory filter deleted, S366 Turbo, 3IN Intercooler pipes, LB7 up pipe/EGR delete, Built trans, DSP5 switch, PPE Fuel press/EGT/Boost guages, 5 In exhaust, Big Chevy Traction Bars, HD Tie-Rod sleeves, Stainless Center Link, ARP Headstuds, Smoked Recon tail lights & brake lights, Smoked headlights/fogs/cab lights-My ATV hauler
Daily Driver 2002 VW TDI 5-speed 49MPG AVG
Tyler
DuramaxHD10 is offline
post #6 of 40 (permalink) Old 02-19-2012, 04:39 PM
xsivspeed454's Avatar
I ran into this on an lb7 just a short time ago. I changed the PVC valve which actually is a little rubber diaphragm that looks like a carbureators accelerator pump. It's located on the drivers side valve cover. It's held down by 4 Phillips head screws. Only takes about 5-10 minutes to change. It's cheap and easy. I would do an oil change and change the pcv and then monitor it.
2003 CCSB 4x4
EFI Tuned by ATP -PPE Stage 5 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Autometer Boost & Pyro -Airdog II 165
xsivspeed454 is offline
post #7 of 40 (permalink) Old 02-19-2012, 05:27 PM
Lincoln Diesel
Aaron@LDS's Avatar
Do all LB7's have PCV's? This is the first time Ive heard this about LB7's
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #8 of 40 (permalink) Old 02-19-2012, 06:09 PM
I believe they all have the PCV system no matter what emission level the truck is. The one I was working on was loaded with all the emissions crap and it had one. My 03 doesn't have any emissions stuff on it (from the factory) and mine has one. All engines have a PCV system as far as I know.
2003 CCSB 4x4
post #9 of 40 (permalink) Old 02-19-2012, 06:16 PM
Lincoln Diesel
Aaron@LDS's Avatar
Huh... Guess you learn something new every day......
-Aaron-
SOLD
post #10 of 40 (permalink) Old 02-19-2012, 06:16 PM Thread Starter
whitey09's Avatar
Thanks for the replies! Tomorrow I will hopefully change the oil and check on getting a pcv valve. It is not a California emissions truck.
110hp EFI live Tune
PPE Boost Valve
whitey09 is offline
