Luke Warm Heat? - Page 3 - Chevy and GMC Duramax Diesel Forum
Old 11-15-2012, 06:49 AM   eBay Motors  #21 (permalink)
Baby maker extraordinaire
ty_LBZ's Avatar
Originally Posted by rd05lly View Post
Center of dash at floor. Is it blowing cool left and right?
If so I would check coolant first take bleeder screw out till coolant comes out. Heat is first thing you lose when low.
Blows luke warm out both left and right vents, seem to be same temp. Will try bleeder screw.
Originally Posted by mikeyg View Post
Either clamp and unhook heater hoses going to the core In the firewall or grab a couple flushing "t"s and flush the core. It will help out tons. Dam dexcool gunks everything up
Ok, will flush the heater core too.
Thanks for the ideas guys, looks like this weekend going to be busy in the garage.
2006 Chevy LBZ 4WD CCSB Resonator sealed. plugged & sticked. re-routed. shimmed. 4" MBRP cat-back(too much drone). Alligator trans cooler hoses. Transgo Jr. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. Bilstein shocks. AC Delco batteries. Daily driver.
Originally Posted by Thomas Jefferson
"I prefer dangerous freedom over peaceful slavery."
Originally Posted by creekr View Post
"The navy seals didn't kill bin laden it was their guns"... Said no one ever
Originally Posted by Clint Smith
"When seconds count, the cops are just minutes away."
OMG! (obama must go!)
ty_LBZ is offline   Reply With Quote
Old 11-16-2012, 05:06 PM   eBay Motors  #22 (permalink)
ty_LBZ's Avatar
Update
Borrowed a temp gun from work, we use these to read electric motors, after driving back from work, I turned the heater full on and measured above the thermostat housing, I got 145*F on heater hose, upper radiator hose also about 143*. I figure the thermostats are gummed up, or have there's a bypass hole in the thermostat that won't allow the engine to get up to 180ish. Going to replace thermostat and flush the heater core this weekend, hopefully I'll be sweating thru winter after that.
Old 11-16-2012, 05:45 PM   eBay Motors  #23 (permalink)
ALLY Cat's Avatar
Actually, Dex by itself is fine, it's just when you mix it with certain other green/yellow brands it may cause it to "gunk up". Not all other brands are compatable with Dex, be careful, read the label if mixing with another product, better yet, just don't mix it with anything else.
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, Ride Rites, LBZ turbo inlet mod, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is offline   Reply With Quote
Old 12-01-2012, 09:16 AM   eBay Motors  #24 (permalink)
ty_LBZ's Avatar
Changing out the thermostats helped, heater is warmer. Might fab up some ghetto winter front covers for the mornings.
