brake booster leaking???? - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 04-10-2012, 09:57 PM Thread Starter
Send a message via AIM to jesselb7
I just replaced my brake booster cuz I was leaking PS fluid from between the brake booster and MC. When I was putting the new booster back on, one of the o-rings from the pressure lines fell off and I couldn't find it. I replaced it and put it all back together but now I'm still leaking PS fluid from where the hard line goes into the booster, not as much as before but it's still pissing me off. Any ideas of what I can do to stop the leaking? I read somewhere that replacing PS fluid with synthetic ATF would help stop the leaking What do you guys think? Thanks.
- Jesse
02 Chevy CC SB 4x4 LB7
EFI Live tuned by Idaho Rob
Edge CTS Insight
EGR Blocked
MBRP 4" Turbo Back Exhaust
DDM HID 4500k lows/3000k fogs
Leveled on Bilstein 5100s
Rare Parts Xtreme Duty Tie Rods
285 BFG All Terrains
jesselb7 is offline
post #2 of 5 (permalink) Old 04-10-2012, 10:07 PM
LHN...We ARE the Joneses
Dino or Syn, shouldn't matter. You sure you have the right replacement?
Hook'em_Horns! is online now
post #3 of 5 (permalink) Old 04-11-2012, 07:58 AM
RichieRich's Avatar
How hard was it to do? The 03 I just picked up has a slight leak between the hydro boost and the master cyl as well. Did you just buy a rebuild kit or replace the boost?
2003 Chevy Silverado 2500HD CC SB Duramax
Airaid Intake, 4" Cat Back Jardine Exhaust, '06 Tow Mirrors, Husky 24k Slider Hitch, Tekonsha Prodigy, Billet Grill, Injectors Done at Dealer at 125k...now has 157k, UltraGauge
Nicktane Adapter and Donaldson filter on its way
RichieRich is offline
post #4 of 5 (permalink) Old 04-11-2012, 08:11 AM
Administrator
jc1843's Avatar
If it is still leaking, replace the hose. The hydro perates on high pressure-- changing to a different fluid will not help.
jc1843 is offline
post #5 of 5 (permalink) Old 04-11-2012, 05:05 PM Thread Starter
I'm pretty sure its the right part. Everything bolted right on and fit correctly, except for the stupid leak... haha.
I just replaced the booster, it wasn't hard, just a PITA. The 4 four bolts going through the firewall and the brake pedal clip were annoying, but besides that its pretty easy.
That makes sense. I figured I would have to do that. Do you happen to know the part # or anything cuz I was looking to see how much it would be but I couldn't find exactly what I was looking for.
- Jesse
Edge CTS Insight
EGR Blocked
jesselb7 is offline
