Changing Injectors - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 04-13-2012, 06:58 PM Thread Starter
Duramaxfan03's Avatar
Changing Injectors
Hey guys i just took my truck to my local diesel specialist to check balance rates on my injectors and i found out i have 3 bad ones. So instead of paying their $90.50 per hr shop rate to change them i think imma try and change all of them myself if i can. Do you guys have any hints or tips for me to make it any easier? Do you think it is worth it for me to do it or should i just take it to them and let them deal with the mess?? Thanks for your help! I hope i can save some money and do it myself
Duramaxfan03 is offline
post #2 of 17 (permalink) Old 04-13-2012, 07:07 PM
Meyer Performance
lutzjk913's Avatar
I am assuming u are talking about a lb7?
Alot of depends on how mechanically inclined u are too.
Joe
Mine: 2008 CCLB Duramax 13.68 @ 98.25
Hers: 2016 Explorer Sport twin turboed V6
The life of my truck
Pics of my truck
lutzjk913 is offline
post #3 of 17 (permalink) Old 04-13-2012, 07:09 PM
Trimmy's Avatar
There not hard to do at all. I just did mine and its easy just a lot of work to get to them.
2007 Classic, CCSB 4x4, EFI DSP5 by Me, Suncoast 1056, Transgo Jr, Ma Pump Rub/Trans Lines, S&B Intake, SDP EGR Delete 3" MBRP Downpipe, 4" MBRP Exhaust, CAT Adapter, Belltech 3" Shackles, Pac Brake Air Bags
Sold: 1999 Quad Cab Short Bed Cummins 4x4 653HP/1412Ftlbs
Billet 47RE, Edge Drag Comp/Smarty, 6x16's, Fass 150, 62/S476 Twins, Spearco Intercooler, o'ringed/ARPs, Ect Ect Ect...
Trimmy is offline
post #4 of 17 (permalink) Old 04-13-2012, 07:34 PM
it depends how confident you are in your mechanic abilities. I did mine 2 yrs ago and my truck still kicking butt. Just read the write up on here one or two times before you start. I took me about 14 hrs, but by no means im a pro, just a weekend warrior.
01 Silverado 2500HD.
EFI Live by ATP.
Banks air intake,
4" turbo back exhaust from banks,
165 gph AD II
18x9 fuel hostages/ 33" toyo open country.
DRMX01 is offline
post #5 of 17 (permalink) Old 04-13-2012, 07:37 PM
jessman388's Avatar
If you like working on stuff they arent bad. Keep a bench clean to put all the parts, stay organized, take pictures, and plan for more time than you will need. Its not too bad really, jsut a little time consuming is all.
2002 CCSB 4x4 LT. Dark charcoal exterior/black leather interior. 20x9 Death Metal Novakanes. 33 12.50 20 MT's. NBS smoked cab lights. Double Din in dash. 5" exhaust. Downpipe. AirDog II 165. Home made 4" intake. Home made traction bars. KrYpTiK Tuned.
jessman388 is offline
post #6 of 17 (permalink) Old 04-13-2012, 07:38 PM
DirtyMaxx03's Avatar
To be honest. It's straight forward. Get under the valve covers and everything is obvious. There is several DIY injector swap threads out there. Find one of those and you should be able to do it. But you can't get pissed if you accidentally fawk up on something and have to tear it back down again.
Sean
2003 Lb7 2wd
Dropped
Efi Live by Rob Coddens
s472
DirtyMaxx03 is offline
post #7 of 17 (permalink) Old 04-13-2012, 11:46 PM
Cowabunga's Avatar
I did the search function and found some procedures that were illustrated unfortunately, it was not done in a clear step by step process. Overall, it does not seem to be very difficult, just time consuming. I'm still looking for that "lessons learned" post that will tell me everything I should not do when it comes my time.
2004 2500HD 4x4 Crew Cab LS 153
120XXX, LB7
K&N Cold Air Intake, 4" SS Exhaust
Edge Insight CTS
Cowabunga is offline
post #8 of 17 (permalink) Old 04-14-2012, 06:02 AM
wheelinstud09's Avatar
How To: Change LB7 Injectors With Pictures!!! here you go man. this is the one i used. it has pictures torque specs and everything. good luck
2001 GMC Sierra 2500HD Duramax ZF6 ECSB K&N Cold Air, 4" MagnaFlow 5"tip. SOLD and KICKING MYSELF!
2003 Chevy 2500HD Duramax ZF6 CCSB K&N Cold Air, Diamond eye 4" duals 5" tips, Exergy 12mm Stroker pump, 45% over injectors from LDS, BD SuperMax, LML Driverside Manifold, South Bend Dual Disk Clutch, Fass Titanium 150, Custom EFI Live tuning, PPE Tie-Rod Sleeves, Edge Insight CTS, Autometer Cobalt Guages
2005 GMC 3500 Duramax Allison Extra cab flat rack 4x4 Single EFI Tune, 3" downpipe 4" exhaust
wheelinstud09 is offline
post #9 of 17 (permalink) Old 04-14-2012, 09:43 AM
Cowabunga's Avatar
Thanks Wheelinstud09.
120XXX, LB7
Edge Insight CTS
post #10 of 17 (permalink) Old 04-14-2012, 08:40 PM
no problem
