Oil PSI at idle... - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 05-07-2012, 08:55 PM Thread Starter
bamadiesel..WFO!!'s Avatar
Oil PSI at idle...
Not necessary limited to lb7's , but i was just wondering what you guys are seeing on your oil pressure at idle and crusing after your truck warms up. I have 198k on my lb7 and at a stoplight for instance with truck at operating temp of around 170 my insite shows 10/11 pounds of oil psi. does that sound right? while crusing i usually get around 30...
2007.5 CCSB
2003 CCSB SOLD
EFI LIVE with Max Effort from ATP TRUCKS, 5" MBRP with DPF delete, SDP EGR delete tube, S&B, PCV reroute, Airdog II 165, Fuel shim, Fuel fittings ported, Edge Insite CTS, Glowshift boost & fuel psi, Transgo Jr., BDS 4.5, Cognito UCA, Ready Lift keys, 35 x 12.5 nitto mt, 20 x 8.5 rockstars
bamadiesel..WFO!! is offline
post #2 of 14 (permalink) Old 05-07-2012, 09:02 PM
SickLL7Crenshaw's Avatar
my lb7 at idle is around yours but 60 psi cruisin at 65
05' LLY CC/SB 12.41 @109.9 119k
Blake
SDP Twinz, 40% overs, EFILive by me, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Henry and Scott
01' LB7 EC/SB 13.5@97 230k
EFILive by me, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLL7Crenshaw is offline
post #3 of 14 (permalink) Old 05-07-2012, 09:48 PM
30 at idle, 60 at 2000 rpm......160k
03 2500 LS, LB7, CCLB
hardtail is offline
post #4 of 14 (permalink) Old 05-07-2012, 10:01 PM
drty_lb7_03's Avatar
Ill check mine tomorrow... I have 190,xxx on mine. WIll post back tomorrow...
2003 ec/sb b7 200,xxx
PPE boost valve
straight piped, CAI
Leveled w/ 285's on stockers!
Autometer PhantomII Boost & Pyro
& other DIY stuff....DSP5 Efi Live
www.NorCalTruck.com & Rigid Ind. FTW!
WWW.TrollPerfomance.com
Originally Posted by KID-DMAX View Post
oh my god....i hope my teacher doesnt see my woody right now....
drty_lb7_03 is offline
post #5 of 14 (permalink) Old 05-07-2012, 10:13 PM
Hunter t's Avatar
Low oil press on guage normal at idle. Or seems to be the norm. anyway
04 GMC duramax LB7
No longer stock
Now straight piped and running EFI live
Aftermarket rims and now running 265's
1st Duramax
Former Power Stroke
Hunter t is offline
post #6 of 14 (permalink) Old 05-07-2012, 10:17 PM
ATPTRUCKS
sickdiesel's Avatar
My old Lbz ran around 25 ish at idle
2017 GMC Denali CC/LB L5P
06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
07 Chevy lbz 4x4 Caged and built 10.42@134 SOLD
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline
post #7 of 14 (permalink) Old 05-07-2012, 10:17 PM
DURAMAXD219's Avatar
Yeah it's normal I asked the same question not to long ago mine is close to 0 lol
Low Oil pressure?
Dylan - LB7
Billet 472 - Dual Fuelers - 45overs - Built Trans
HSP - PPE - LDS - Inglewood
Sponsored by OPDT, Thanks Josh
12.68 @ 110.7
6850lbs
DURAMAXD219 is offline
post #8 of 14 (permalink) Old 05-07-2012, 11:56 PM
chevyrz28's Avatar
Mine runs around 60 psi cruise and macs the gauge out at wot
chevyrz28 is offline
post #9 of 14 (permalink) Old 05-08-2012, 09:29 AM
I think mine is more around 20 psi at idle.
2001 LB7 2500HD Duramax, leveling kit, edge chip, AFE intake, 4 inch diamond eye exhaust, 305/70R16 Toyo MT.
MikeyBuck is offline
post #10 of 14 (permalink) Old 05-08-2012, 09:33 AM
20 psi at idle, 60psi on the road. 135,000 miles on it.
S&B CAI, 4" STAINLESS STEEL EXHAUST, EFI LIVE FROM ATP TRUCKS, EDGE CTS, PPE BOOST VALVE, AIR DOG II 165, REBUILT TRANNY WITH SUNCOAST KIT, TRANSGO SHIFTKIT AND BILLIT TORQUE CONVERTER, NEW UPGRADED TAILSHAFT, PUMP RUB FIX ON TRANSFER WITH NEW ALUMINUM TAIL SHAFT, NEW TOW MIRRORS, NEW GAGE HEAVY DUTY FRONT AND REAR BUMPERS, BEANS SUMP, FUMOTO VALVE, RARE PARTS TIE RODS WITH COGNITO PISK, MAD JACK FUEL FILTER ACCESS DOOR, STAINLESS STEEL SPEED BLEEDERS.
mray is offline
