Replacing carrier bearing on 2 piece driveshaft? - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-10-2012, 07:26 AM Thread Starter
duramax-rob's Avatar
Hey all,
The carrier bearing on my 01 4 dr dually 2 piece drive shaft needs to be replaced. Is this a fairly easy job or should I take it to a driveline shop to have it done. Any help would be appreciated. I don't have a press but can take it to a parts store that has one if needed. Thanks
duramax-rob
__________________________________________________ __________________________________________________ _
2001 Chevy 3500 CC Longbed Dually 4X4, 6.6 Duramax, PPE Standard, Magna Flow 4" Exhaust, Gooseneck hitch, 32' Gooseneck Trailer, Allis Chambers Backhoe
Some's good, More's better, Too much is just enough!!!!
http://www.alligatorperformance.com/ http://www.alligatorperformance.com/
duramax-rob is offline
post #2 of 6 (permalink) Old 05-10-2012, 07:46 AM
Administrator
jc1843's Avatar
The carrier bearing is pressed on-- some have been able to remove it with a puller.
I suggest you take it to a drive shaft shop, and have them replace the bearing and the u-joints. Then it will be good for a long time. Replacing U-joints can be tricky, if you have never done it before.
jc1843 is offline
post #3 of 6 (permalink) Old 05-13-2012, 07:15 PM
03maxin's Avatar
An air hammer and cut off wheel should work
2003 Silverado CC LT
K&N filter, AMS oil, PPE boost increase valve, 20% tint,
Fleetgaurd fuel filter, removed door moldings, 4" MBRP exhaust
81 Corvette
Black with silver int. Built 355 with chrome Hooker Header side pipes,
TH350C trans with transpac kit, electric fan, Holley 650 double pumper,
MSD Ignition, NKG plugs
03maxin is offline
post #4 of 6 (permalink) Old 05-14-2012, 10:20 AM
LB7Chevy's Avatar
I was able to get mine off with a puller but then I took it to a driveline shop to get the new one pressed on, new u joints, and balanced again,,,,,saved me a little money that i had it outta the truck and the bearing off
2001 2500HD CCSB EFI Live - Edge Insight CTS - BatMo stocker - Profab air horn - 4" intake with S&B - 3" IC tubes - Profab down pipe - 4" MBRP with 5" tip - LML manifold - CAT adapter/filter - Boost Valve - Autometer Sport Comp II Boost & Pyro - Leveled front - 20x9 Ballistics with 305/50/20 Toyo ATII - Bilstein 5100s - Moog Idler/Pitman - Debadged - Recon smoked LED tail lights, 3rd, & cab lights - 5% tint - traction bars
1992 1500 SCSB 383stroker/SM465/NP200 - 2.5ton rocks - 44" boggers - leaf sprung - building 4 link with mini subframe as we speak
Instagram: @aksnelly
LB7Chevy is offline
post #5 of 6 (permalink) Old 05-16-2012, 06:14 AM Thread Starter
Thanks for the replies. Would it be best to drain the tranfer case before pulling drive shaft or just catch what drains out? The seal in the back of the transfer case is also leaking, can that be replaced from the outside in the truck or does the transfer case have to be taken apart?
Thanks to ya'al from Arkansas!!!!!!!!! The, we're all related state!!!!!!
duramax-rob
post #6 of 6 (permalink) Old 05-16-2012, 06:27 AM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
You shouldn't leak anything and it will be very little if you do once shaft is pulled.
I swapped that seal when I dropped my tcase to install a pump rub kit. But should be able to do it up there pretty easily.
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
