2003 Duramax won't start when hot. - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-12-2012, 10:35 AM Thread Starter
I have a 2003 2500 HD that will not start when hot. It starts fine when cold and runs great. No smoke and plenty of power. Once the engine heats up if you shut it down it won't start for at least 2 hours until completely cooled off.
I have taken it to the GM dealer who tested it and said it might be the injectors but he wasn't sure as they all tested fine. He couldn't find the problem. The only thing he did was replace the pressure release screw on top of the fuel filter housing. That seemed to help a little for a short period of time.
I have replaced the fuel filter (GM produce) five times in less than 100,000 miles so I don't believe that is the problem.
Any ideas how to fix this problem?
Thank you!
Bhenriksen is offline
post #2 of 6 (permalink) Old 05-12-2012, 10:52 AM
duramaxallison's Avatar
Have the return rates on the injectors checked. I heard this has been other peoples problems.
2003 LB7 2500HD ECSB
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-35w AGT 6000k HID's
-5% tint allaround
-285/75R16 Michelin LTX A/T 2s
-340k miles and counting
-Daily Driver
duramaxallison is offline
post #3 of 6 (permalink) Old 05-12-2012, 11:47 AM Thread Starter
If the return rates are off does that mean new injectors?
Thanks
post #4 of 6 (permalink) Old 05-12-2012, 12:46 PM
Lincoln Diesel
Aaron@LDS's Avatar
I would say injectors returning too much fuel is a good possibility also. Do the bottle test when warm, and try a good injector cleaning. There are excellent writeups here about both.
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #5 of 6 (permalink) Old 05-12-2012, 01:27 PM
Administrator
jc1843's Avatar
Common problem with bad injectors on the LB7 engine. When the engine is warm, they by-pass to much fuel, and the rail pressure is low.
jc1843 is offline
post #6 of 6 (permalink) Old 05-13-2012, 01:23 PM Thread Starter
If a fuel pump was installed would it bring the rail pressure up so it would start?
