lb7 cali emissions - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 25 (permalink) Old 05-14-2012, 11:22 PM
audiomixer's Avatar
Originally Posted by YAMAHA1 View Post
as far as the cat, never had it. i bought the truck brand new and it never had it. infact this makes me wonder if it has anything for emissions. my truck was one of the first duramaxes in our area. funny thing is just to be an ass i stopped at a stealership here in town that i had problems in the past with and asked them if they had a 4wd, crew cab dually duramax. the f*k'n salesman laughed and said with a cocky attitude " good luck finding that truck, ur just lucky to find a regular cab with the duramax." so on the way back from grabbing my new D-Max dually i stopped at the same dealership. well when i parked it a bunch of salesmen came out to check out the truck, for some of them it was the first crewcab D-Max they had seen in person. when i seen the dumbass sales guy, i rolled down my window and said " f*K this must be my lucky day". rolled up the window and drove away. anyway the look on the guys face when he seen it was me, PRICELESS.
2001 MY truck with LB7 both CA and fed emissions did not have cat nor EGR. Cat and EGR started with the 2002 MY for CA emissions.
Chevrolet '16 2500HD 4WD LTZ CC D/A LML Deep Ocean Blue, stock.
GMC '04 2500HD SLE CC D/A LB7 SB Summit White, LineX, Nicktane, JK headlight harness, JK fuel pump and harness, Banks exhaust, EFI Live, intake horn mod, Suncoast 6 speed conversion.
VW '01 Bug TDI 6 spd ERF manual, 11mm IP, DLC 520 injectors, Malone stage 2 tuning. My FUN summer driver.
audiomixer is online now
post #12 of 25 (permalink) Old 05-27-2012, 04:15 PM
I have a 02 with the cali emissions, I want to do away with all of that, pump is making horrible noises now anyway, i bought a blocker plate to go into the exhaust, but what about the relays and the cooler tube? can anyone tell me what i need to do away with all this on the motor and in the exhaust, to be done the best way. dealer will flash the computer to standard emissions if i can remove everything
ftgulal is offline
post #13 of 25 (permalink) Old 05-27-2012, 04:33 PM
Banned
I dont think the dealer will do that...
Best way is to buy a non emissons Y bridge, shorted OEM belt from non emissions 02, and a passenger up pipe to totally delete the EGR. Then tune it to rid the ecm of the CEL's.
Hondarider552 is offline
post #14 of 25 (permalink) Old 05-27-2012, 04:42 PM
X2 on what Brian said,....
the heads are also a little different and so is the turbo flange IIRC
Zac
2003 LB7 White EC/SB
EFI by Rob w/DSP 5 / Danville stage 2 68mm turbo/ BigDipper trans with ML converter(built by Todd=Stroke 250) / Raptor 150 / Big Dipper 45% over injectors / Wicked Stage 3 Stroker pump / 4in MBRP dp back to a 6" black Mitre cut stack / 8000K HID Hi/Low / Recon smoked LED tails, cabs, and 3rd brake / Rancho 9000's / DHD Steering brace
Originally Posted by blacksmokelb7 View Post
Rather see mama in a whore house then a brother in a dodge
zacwht20 is offline
post #15 of 25 (permalink) Old 05-27-2012, 04:42 PM
thanks, will start shopping, any vendors here that would carry everything
ftgulal is offline
post #16 of 25 (permalink) Old 05-27-2012, 10:49 PM
audiomixer's Avatar
Do not remove the 2nd baro sensor that is behind the fuel filter. It only needs to be electrically connected so the ECM can "see" it. If you remove it you will get a P2227 baro sensor code and your performance will suck. There is no setting in EFI that I'm aware of that will prevent this code should the sensor be removed (from Guy at SoCal diesel). If you remove all of the other solenoids, there are more DTC MIL and test enablers that needs to be set to "Not reported." They are: P0401-P0409, P0489-P0490, P1404,P2141-P2145.
Also B1501 to 300, B1504 to -39 and B1505 to 151 to disable EGR function.
That should do it.
If you are not running a big tune, simply disabling the system is sufficient to stop EGR function since it takes 20lbs of boost to overcome the spring of the vacuum operated EGR valve. Its the cheapest blocker plate you can get. Try this first before you drop coin on up pipes and stuff to remove the cooler. I left my cooler in place along with my EGR valve. Only thing I removed was the pump and solenoids and saved some money in the process.
post #17 of 25 (permalink) Old 06-01-2012, 09:48 PM
so i have removed the pump, what do i do with the vacuum lines now, remove or just cap it
ftgulal is offline
post #18 of 25 (permalink) Old 06-02-2012, 10:05 PM
RichieRich's Avatar
Does it sound better?
2003 Chevy Silverado 2500HD CC SB Duramax
Airaid Intake, 4" Cat Back Jardine Exhaust, '06 Tow Mirrors, Husky 24k Slider Hitch, Tekonsha Prodigy, Billet Grill, Injectors Done at Dealer at 125k...now has 157k, UltraGauge
Nicktane Adapter and Donaldson filter on its way
RichieRich is offline
post #19 of 25 (permalink) Old 06-02-2012, 10:34 PM
kivetts04dmax's Avatar
don't wanna hyjack, but how can I pass emissions in Cali for base if I don't have an egr at all or a cat? I have an 04 lly
2006 CCSB LBZ -FPE Billet S472 w/HSP Kit, Studded, Plugged, Deleted, Levi's Blankets, 3" Drop Shackles, OLs removed, Braces, Kryptonite Front End, Electric Fans, Suncoast GMAX6, MA Trans Brace, Pump Rub, Transgo, MagHytec Pans, Magnaflow, Rigid, Alligator, PPEI Tunes, 305/50 Nitto 420s, 20x10 Fuel Couplers, Trac Bars by LWATSON
2004 RCLB ZF6 LLY -SOLD
Billet S472, Southbend DD
2004 CCSB LLY -SOLD
kivetts04dmax is offline
post #20 of 25 (permalink) Old 06-02-2012, 11:11 PM
tigermack's Avatar
Send a message via AIM to tigermack
Anyone know how to get rid of the EGR and all that without having codes? I know places that can pass emission without looking...
03' EC LB7 2WD
T6 Rotella - Napa oil filter
Amsoil Torque-drive - Napa filter
PPE standard & boost valve | Bilstein 5100's | Prosport EGT & boost gauge w/ Autometer dual overhead pod | Pioneer Avic D3
tigermack is offline
