02 duramax wont start - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 07-29-2012, 01:31 PM Thread Starter
have an 02 duramax that wont start. tried a new primer pump checked compression good,had rpm on scan tool no codes, sounds like its out of time so pulled front cover and not seeing anything out of wack . put little ether on a rag and still doesnt even try. anyone have any suggestions?
andy ray is offline
post #2 of 21 (permalink) Old 07-29-2012, 01:34 PM
Welcome, any codes?
S&B CAI, 4" STAINLESS STEEL EXHAUST, EFI LIVE FROM ATP TRUCKS, EDGE CTS, PPE BOOST VALVE, AIR DOG II 165, REBUILT TRANNY WITH SUNCOAST KIT, TRANSGO SHIFTKIT AND BILLIT TORQUE CONVERTER, NEW UPGRADED TAILSHAFT, PUMP RUB FIX ON TRANSFER WITH NEW ALUMINUM TAIL SHAFT, NEW TOW MIRRORS, NEW GAGE HEAVY DUTY FRONT AND REAR BUMPERS, BEANS SUMP, FUMOTO VALVE, RARE PARTS TIE RODS WITH COGNITO PISK, MAD JACK FUEL FILTER ACCESS DOOR, STAINLESS STEEL SPEED BLEEDERS.
mray is offline
post #3 of 21 (permalink) Old 07-29-2012, 01:50 PM
bigjohn's Avatar
You getting fuel to your fuel filter .
2006 GMC Sierra 2500 HD SLT ECLB, LBZ, LED tailights, black turn signals , black aftermarket headlights,265/75/16s uniroyal larados,Bilstein shocks,Banks 4inch exhaust, Nicktane adp, with a 3 micron Donaldson fuel filter, Schaffer's oil, pcv Re-route from alligator performance, Nicktane race plug, GM cab light,Banks 3 inch boost tube,And S&B air intake good to be driving a diesel again.
2002 2500 HD CHEVY Silverado ECLB LB7
bigjohn is offline
post #4 of 21 (permalink) Old 07-29-2012, 01:52 PM
So we'll assume its cranking, just not starting. Could be sucking air, bad injectors, cp3 shot.
2002 with 125K. Injectors and HP fuel lines from Lincoln diesel at 113K.
rdsoxx is offline
post #5 of 21 (permalink) Old 07-29-2012, 02:21 PM Thread Starter
ya it cranks but wont run i replaced the fuel primer assemebly and it pumps up and gets hard . no codes . but shouldnt it try to start on ether? even if it had bad injectors
andy ray is offline
post #6 of 21 (permalink) Old 07-30-2012, 01:23 PM
dont use starter fluid with the dmax. do you have access to a programmer that reads diagnostics? it would be good to know your actual fuel rail pressure to confirm you're getting fuel and how much. you could have a buddy pump the primer while you try to start it. there are quite a few causes for these not starting.
rdsoxx is offline
post #7 of 21 (permalink) Old 07-30-2012, 01:33 PM
KyBowtie's Avatar
Happened to me a few times
And I just primed the piss putt it and it would start. Sounds like you've tried that thought :/
Sent from my iPhone using Autoguide
Logan Faehr
07 LMM LTZ|ATP|ADII|5" mbrp|3" downpipe|PCV reroute|S&B intake|All season brace|MA sleeves|Recon|Cognito keys|Bilsteins|20x12s|Toyo MTs| Big Dipper tranny soon to come
KyBowtie is offline
post #8 of 21 (permalink) Old 07-30-2012, 06:33 PM
redneck6821's Avatar
sub'd. currently having the same problem as the truck sits in the drive way. it is driving me insane. I know my injectors need replacing but the truck ran that night and then wouldnt start the next morning but it will crank all day long. can a injectors get stuck open or maybe fprv get stuck and cause this?
02 GMC ccsb
Fabtech 8" lift
38" Kumho Road Venture MTs
18" American Racing ATX rims
mbrp 4"
K&N CAI
Pioneer 7" indash DVD
nicktane adapter
redneck6821 is offline
post #9 of 21 (permalink) Old 07-31-2012, 07:48 AM
redneck - what is your rail pressure demand and actual. a stuck open injector could cause your starting issue. however if it happens to you when your truck sits overnight, you are likely losing prime, it appears from your sig you do not have a lift pump, so it could be prime. I'm in CT too, and my supply lines are rusted, and i had to replace a part of the 1/2" supply line near the return fuel cooler. I had the exact same issue, crank and crank. i noticed a fuel drip near the tank. fixed that, problem gone.
rdsoxx is offline
post #10 of 21 (permalink) Old 07-31-2012, 08:15 AM
jakemax04's Avatar
I know it sounds crazy, but check the bleeder screw on the fuel filter housing. Mine was stripped out and the truck would crank all day with no fire. It was sucking all kinds of air through that screw.
2004 LLY, AFE turbo back, S&B intake and Mouthpiece, OH Gauges, Suncoast Gmax 5 put together by yours truly Heyyaa, Precision converter, billet input and output shafts, built trans tunes from idaho rob, DSP5, egr delete, snow performance mpg max, Airdog II, MA Tcase brace, Traction Bars, cognito supports
12.61@106 mph
jakemax04 is offline
