Old 05-18-2008, 09:26 AM   eBay Motors   #21 (permalink)
Stalter
Points: 192, Level: 3
Points: 192, Level: 3 Points: 192, Level: 3 Points: 192, Level: 3
Activity: 0%
I just bought my 01 2500HD and I am having the same problem. 115,000 miles, all stock. Should I get then FPR checked out? This is my first diesel so my learning curve will be steep.
Thanks in advance,
Dustin
Stalter is offline   Reply With Quote
Old 05-18-2008, 09:46 AM   eBay Motors   #22 (permalink)
GoldDigger
Points: 1,389, Level: 14
Points: 1,389, Level: 14 Points: 1,389, Level: 14 Points: 1,389, Level: 14
Activity: 0%
Mine would surge and smoke at idle. Dealer replaced 2 injectors and the injector pump. It was under 100K so it was 100% covered. With over 100K you should only have a $100 deductible.
'05 Chevy 3500 CC 4x4, Edge Juice, 5" Straight pipe Turbo Back, Ranch Hand Grill Guard
GoldDigger is offline   Reply With Quote
Old 05-18-2008, 03:20 PM   eBay Motors   #23 (permalink)
Stalter
Activity: 0%
No warranty...what do you think it would cost? FPR? INJECTORS?
Old 05-22-2008, 10:05 AM   eBay Motors   #24 (permalink)
duradude6.6
Points: 692, Level: 9
Points: 692, Level: 9 Points: 692, Level: 9 Points: 692, Level: 9
Activity: 0%
duradude6.6's Avatar
FPR? is that the one on the fuel rail?
duradude6.6 is offline   Reply With Quote
Old 05-22-2008, 12:42 PM   eBay Motors   #25 (permalink)
GoldDigger
Activity: 0%
The fpr on gm parts direct seemed reasonably priced. It was cheaper than the dealers. I think the fpr is on the pump.
Old 05-22-2008, 01:47 PM   eBay Motors   #26 (permalink)
Bryan@ATS Diesel
ATS Tech Support
Points: 2,306, Level: 19
Points: 2,306, Level: 19 Points: 2,306, Level: 19 Points: 2,306, Level: 19
Activity: 4%
Activity: 4% Activity: 4% Activity: 4%
Bryan@ATS Diesel's Avatar
Its actually on the drivers side in the center of the fuel rail.
2003 GMC Sierra LB7
ATS *EXTREME* Transmission, ATS Aurora 4000 MST, ATS Dual 4" Exhaust, ATS Epower Programmer, Custom 4" Intake with AFE Filter, ATS Billet Tie Rod Sleeves
www.atsdiesel.com
866-230-4092
Bryan@ATS Diesel is offline   Reply With Quote
Old 05-23-2008, 12:28 PM   eBay Motors   #27 (permalink)
GoldDigger
Activity: 0%
I sit corrected.
Old 05-23-2008, 10:08 PM   eBay Motors   #28 (permalink)
GoldDigger
Activity: 0%
Isn't the relief valve on the rail and the regulator on the pump?
Old 05-23-2008, 10:16 PM   eBay Motors   #29 (permalink)
jaydawg
Points: 666, Level: 9
Points: 666, Level: 9 Points: 666, Level: 9 Points: 666, Level: 9
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
jaydawg's Avatar
The FPRV (fuel pressure releif valve) is on the rail, and the FPR (fuel pressure regulator ) is on the injection pump. On the LB7 the FPRV is on a junction block on the drivers side, located with the pressure sensor...any other quesions??? J/J
jaydawg is offline   Reply With Quote
Old 05-27-2008, 09:19 AM   eBay Motors   #30 (permalink)
d21
Points: 729, Level: 10
Points: 729, Level: 10 Points: 729, Level: 10 Points: 729, Level: 10
Activity: 0%
did you guys figure out the problem, because i've replaced all of my lines and the junction block and that did nothing does yours pull fine with this problem?
d21 is offline   Reply With Quote
