Transmission fluid change - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 10-02-2012, 08:41 AM Thread Starter
I'm gonna change my transmission fluid on my 2003 2500HD this weekend (right after I get done changing out the injectors) and was wondering what the fluid capacity it. It has the stock pan and I will be replacing both filters. On another note I also plan on looking into a belt squeak that I have, the belt was replaced about 10k ago, is there any of the pulleys or is the tensioner prone to going bad on these trucks?
pavlaker is offline
post #2 of 9 (permalink) Old 10-02-2012, 10:39 AM
georam1's Avatar
As a general rule they don't recommend changing the internal filter unless you are rebuilding the transmission. If it has never been changed before and you are going to use transynd then you need to do a double change. Drain, change the spin on filter, fill,(about 2.5gal) run it about a week, then drain and refill again.
2003 Chevy 2500hd CC Stock with Cat Filter
2008 Jayco Eagle 31.5 FBHS 5th Wheel
georam1 is offline
post #3 of 9 (permalink) Old 10-02-2012, 11:23 AM
CancerJCC's Avatar
Wierd i am changing trans fluid this weekend and also have a belt squeal! Haha i bought 5 gallons of amsoil $$$ to cover my trans and tc. Both filters will be swapped on mine. I read you need 12 qts for a full flush though and about 7 if your not dropping the pan.
03' CC/SB. HP Tuners. Amsoil Throughout.
CancerJCC is offline
post #4 of 9 (permalink) Old 10-02-2012, 11:53 AM
georam1's Avatar
Before you guys jump without looking read this thread. It's long but full of really good info.
Former Allison Fluids Engineer (Here to Help) - Diesel Place : Chevrolet and GMC Diesel Truck Forums
georam1 is offline
post #5 of 9 (permalink) Old 10-03-2012, 11:52 AM
CancerJCC's Avatar
Thanks ill check it out.
post #6 of 9 (permalink) Old 10-03-2012, 01:54 PM
Earnhardtfan's Avatar
Depending on the mileage you can swap out the tensioner and both idler pulleys. Plus, get a gatorback serp belt and no problems for 100K. Good luck.
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 445K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is offline
post #7 of 9 (permalink) Old 10-03-2012, 04:25 PM
x2 on Gatorback belt. I replaced tensioner and idler pulleys and it still squeeked. Got the Gatorback and not a single word has come from it for 12k miles.
Sent from my PC36100 using AutoGuide.Com Free App
2003 2500 LB7
{5" Diamond Eye Exhaust} w/ 5" to 7" SS Tip
{K&N Filter/Intake}
Shout Outs!
- Willie @ http://www.syntheticmotorsports.org/
- This could be you!
Glowing "LB7" Coal is offline
post #8 of 9 (permalink) Old 10-03-2012, 04:43 PM
CancerJCC's Avatar
They are good belts no doubt, thanks guys.
post #9 of 9 (permalink) Old 10-04-2012, 11:11 PM Thread Starter
Thanks for all the replies, both concerning the belt issue and the transmission, one more question though. This may seem kinda dumb but this is my first time with not only a diesel truck but also working with a transmission that uses 2 filters. Ive decided to just change the spin on filter, what is the proper procedure. Just simply spin off and spin on a new one or do I drain the fluid in the pan along with the filter change.
pavlaker is offline
