'01 duramax no start - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 12:20 PM   eBay Motors  #11 (permalink)
Originally Posted by 04lb7zf6truck View Post
What is this 6.6L Cranks but Doesnt Start flow chart from gm.??? Where can i get a copy of this?
Thanks, Wes
im not sure how to give it to you. its password protected from gm repairprocedures.com so i cant link it. i have it copied as a word doc but i dont see anyway to add an attachment.
pm me with your actual email address and send it to you.
Jamie's Garage, med/heavy truck service, morrisville VT
jamiesgarage is offline   Reply With Quote
Old 11-19-2012, 01:12 PM   eBay Motors  #12 (permalink)
04lb7zf6truck's Avatar
Sent you pm.
Thanks, Wes
Wes--2004 Chevy 2500HD 4dr CCSB
The goodies.....zf6 valair DD/carrillo rods,arp main studs and head studs,75% injectors, comp cam....20 inch BMF Novakane/Trail Grapplers....Evan Davis Tune..Just enough stuff to turn heads at the grocery store
04lb7zf6truck is offline   Reply With Quote
Old 11-25-2012, 01:00 PM   eBay Motors  #13 (permalink)
installed 2 new batteries, still cranked slow. added new cables to starter. cranks good now, still wont start. noticed a puddle under the tank and found another leak, this ones in the return line.
is there a check valve for the return line? when i pump the primer i get a solid stream from the return line and loose my prime over a few minutes.
Old 11-25-2012, 05:23 PM   eBay Motors  #14 (permalink)
If you rebuilt or replaced the filter head & are still losing prime, I'd change the fuel lines from the filter head.
slydog is offline   Reply With Quote
Old 11-25-2012, 08:02 PM   eBay Motors  #15 (permalink)
i guess i dont see how the filter or filter head have anything to do with a steady stream of fuel from the return line when the system is primed?
Old 11-25-2012, 08:06 PM   eBay Motors  #16 (permalink)
rd05lly's Avatar
Bottle test FPRV.
05 CCSB EFI Live by Kory Willis
76 Dodge Charger SE
http://www.duramaxforum.com/forum/91...mber-list.html
www.TrollPerformance.com
rd05lly is offline   Reply With Quote
Old 11-27-2012, 10:26 AM   eBay Motors  #17 (permalink)
The hand pump on top of the filter head has seals that leak and you will lose prime, usually after the truck has sat for a while. The fuel lines from the filter head are prone to leaking too. If the suction line to the tank has been replaced with a regular fuel line, it could (or the interior liner) collapse, and cut-off supply. I replaced mine from the stock metal line below the exhaust with hydraulic hose all the way to the tank. The return line is low pressure & I just used regular fuel line, both approved for diesel. Good Luck!
Old 11-28-2012, 02:42 PM   eBay Motors  #18 (permalink)
would a stuck open FPR cause fuel to return to tank?
i have the return line disconnected and i can watch a stead stream come out when the primer is pumped.
i cant seem to get an answer as to what retains the pressure at the rails from returning to tank. ive got my district trainer calling his contacts at gm, i called the local chevy dealer today, ive checked the gm manuals. man i dont understand why this is such a hard question to answer.
Old 11-28-2012, 07:05 PM   eBay Motors  #19 (permalink)
rd05lly's Avatar
The FPRV can cause this bottle test it if it fills up while your trying to start truck it is bad.
What mods are done to the truck?
Bad injectors can return to much fuel to start as well do a return rate test.
76 Dodge Charger SE
Old 12-17-2012, 05:52 AM   eBay Motors  #20 (permalink)
ive been told that the 01 doesnt have a FPRV.
i called the gm tech line and the guy said my FPR was stuck open. replaced it and still nothing, still has a steady stream returning to tank when primed.
also it wont run up on a shot of ether, it did a few weeks ago, i had it running for around 5 min, thought i had it until it died.
