| Ok, my only deal is there's an issue with the security system, it is hard wired to the fuse Bo by a switch to bypass it.. Will flash the security light and once in a while it will turn off and seem like it shuts the truck off quick then back on... I need to figure that out, also have an edge programmer that I would like to take out anyone have a wiring diagram for it? I may have an issue with the filter head and electrical . Also engine code was for 2 injectors |
| did u figure it out yet? mines doing the same thing. i tried uninstalling the banks and the truck wont start at all.... |
| | eBay Motors #13 (permalink) |
| was a combination of the cp3 pump going out...shut down after i got the new one in, took out the edge programmer and it has been good since (fingers crossed lol) |
| i replaced injectors on an 02 for a guy and i had a delivery tube(high pressure line) leaking which caused it to not even start.... obviously thats not your problem but it goes to show how finiky these fuel systems are.. one little leak will cause it to do some weird shit
