Just Bought Water Damaged Duramax - Page 10 - Chevy and GMC Duramax Diesel Forum
Old 01-02-2013, 05:50 AM   eBay Motors  #91 (permalink)
poosniffer's Avatar
Thanks.Subscribing for the outcome.
2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket calibration,Nicktane with Baldwin BF7587,PPE lift pump with Baldwin BF1212 water separator,285/75/17 Dura Grapplers on H2s,CTS Insight with pyro,Large fender mod.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline   Reply With Quote
Old 01-03-2013, 09:34 PM   eBay Motors  #92 (permalink)
Breaking News!!!! She lives!!!
A different guy came over and hooked up the Tech 2 and hooked up the vacuum gauge to the test port. After noticing some slow cranking on my charger we bumped the amperage up. After the bump,for some unknown reason, it cranked up and started running as smooth as one that's driven daily. Balance rates were really poor and had a roughy idle. After a few minutes they'd started to level out. I haven't put it in gear yet though. The fuel filter separator was leaking on the bottom and I have a new sensor and filter to install. The got the vacuum gauge on the test port up to 8 or so and it stayed at 2 for awhile and then dropped some. I had already orderd the orings and seals to rebuild this anyways off eBay.
Balance Rates- after initial 12 mins of running. First time I heard it running!
1 -2.3
2. 0.7
3. -1.7
4. 3.7
5. 1.3
6. 1.9
7. -1.6
8. -1.8
I'm going to go tomorrow, drain the oil again, add new oil and filter.
Although I still have a long way to go, I want to thank all the board members for there help, especially the ones that have delt with my PM's!
2002 Chevy Duramax-Crew Cab 4x4 SB
IT RUNS!!
Cowansauto is offline   Reply With Quote
Old 01-04-2013, 01:19 AM   eBay Motors  #93 (permalink)
krtp1's Avatar
Congrats man!
2007.5 Chevrolet 2500HD - RCLB LT Z71 - Eagle 050 18s with 275/65-R18, blacked out emblems and tool box, EFI LIVE DSP5, 5" Diamond Eye exhaust with 6" tip, Edge CTS Insight, EGR turned off.
2006 GTO - Pacesetter Headers, catless mid-pipe, tinted, painted OEM 18 inch wheels, flowmaster axle-backs, aluminum driveshaft, 0 drop rear springs.
2004 Harley Davidson Sportster
1955 Belair - World Products Sportsman II Heads, 750 Double pumper Holley, Hooker Headers, 305/525 Comp Cam, 4 Speed, Weld Racing Wheels, Edelbrock Intake, MSD, few other odds and ends.
krtp1 is offline   Reply With Quote
Old 01-04-2013, 04:04 AM   eBay Motors  #94 (permalink)
CancerJCC's Avatar
Excellent news!
03' CC/SB. HP Tuners. Amsoil Throughout.
CancerJCC is offline   Reply With Quote
Old 01-04-2013, 04:58 AM   eBay Motors  #95 (permalink)
Firefighter08's Avatar
Let us know when you take it for a drive. I'm curious to see if it shifts.
Jacob
2008 SLE GMC C/C.
4" mbrp, FTE resonator, EFI from duramaxtuner, blocked and rerouted. CAT filter adapter with Donaldson filter.
Firefighter08 is offline   Reply With Quote
Old 01-05-2013, 09:41 PM   eBay Motors  #96 (permalink)
After letting the truck run for about 45mins. I drained the oil and it came out like Yoo Hoo! Mixed up 7qts oil and 3 qts Kerosene let the truck run for 30 mins or so. When this was drained it looked a lot better. Added straight diesel oil and new filter. Probably change the oil again after I drive the truck some more.
Drove it down the road, about 2 miles or so and noticed some hesitation in the shifting. It slipped some and revved up a little too high for the speed the Truck was moving at. The slipping was probably due to watered down fluid that was still in the tranny and/or low fluid. It did throw some Transmission related codes when I first got it moving. After the truck (fluid) got warmed up, I cleared the codes and drove it for a little more and they have not come back.
Drained the fluid overnight with the pan and filters out and replaced both filters this afternoon along with more new fluid. The old fluid that came out had a nice tint to it, not like the strawberry milkshake I found in the pan the first time I drained it.
IT RUNS!!
Old 01-06-2013, 09:08 AM   eBay Motors  #97 (permalink)
02Dirtyymax's Avatar
Nice news man! Gotta love when something finally starts working after being worked on.
The transmission might be shot, only thing you can really do is drain, fill run drain fill.
This should be your next little project is getting that motor to run great How To: DIY - Injector cleaning
tranny can be rebuilt back to stock for around a grand or so.
02Dirtyymax is offline   Reply With Quote
Old 01-06-2013, 09:26 AM   eBay Motors  #98 (permalink)
Spoolin' Up
Hibneck1's Avatar
sub'ed!
2006 Chevy 2500HD Duramax Allison ECLB
Mods: 5000k 55w HIDs in high, lows, 4300k 55w in fogs, all on mod, PPE Air box mod, blocked and stuck, PCV re-route and resonator kit, 5" Diamond Eye Turbo back with 7" tip, raptor liner from body line down and holding up perfect!
Waiting to be installed: Cognito 4"-6" with hd sway bar, ballistic jester camo 17x9 rims with 315/70 R17 Treadwright Guard Dog M/T's, Fabtech tie rods, pump rub kit, moog ball joints and pitman/ idler arm
Hibneck1 is offline   Reply With Quote
Old 01-06-2013, 10:16 AM   eBay Motors  #99 (permalink)
good to hear running!! ive been watching this thread glad you brought her back from the dead..
if you don't mind me asking how much did you buy this thing for any way
free2reem is offline   Reply With Quote
Old 01-10-2013, 11:00 PM   eBay Motors  #100 (permalink)
Glad you got it running! I do a bit of salvage rebuilds myself. Always stayed away from the water damage. Knowing my luck I'd get a salt water one and it'd be scrap.
Sounds like you've got a pretty penny in fluids already as many times as you replaced them. Good luck!
2003 GMC Sierra 4x4, Duramax, ZF6 Swap, South bend DD, Airdog, AFE intake, MBRP Exhaust, Edge Juice w/CTS, B&W w/ Firestone Airbags, Cat filter
In the mail:
EFI Live from Idaho Rob w/ V2 and Edge CTS.
wvchrome is offline   Reply With Quote
