| Junior Member Join Date: Oct 2012
| Just Bought Water Damaged Duramax Just picked up a 2002 CC 4x4 DMax that had some type of water damage. Haven't determined how deep it got, but the engine bay is covered in dirt. The oil dipstick doesn't show any signs of water. The transmission stick does show some white sludge which I figured was water. Here's my plans: 1. Attempt to turn balancer by hand to check to see if engines locked up. 2. If it spins free, drain all oil and check for water 3. Pull valve covers off to check for sludge 4. Drain front diff 5. Pressure wash engine and dry with blow nozzle What else would you recommend? |
| Duramax Lifetime Supporter ![]() Join Date: Jul 2012 Location: butler, pa
| Spay all wiring with some wd 40 and use some dielectric grease on all connections.
__________________ 2007 Classic lbz Turbo back exhaust, Efi live auto cal from idaho Rob egr blocked, trans go jr, grizzly locker,leveled 285-75-16 wrangler duratracs radials on pro comp wheels,remote start, afe intake air dog 165, billstien 5100s,Afe intercooler pipe, pcv valve reroute, diamond eye down pipe , bushwacker pocket flares, BD exhaust manifold, g2 diff cover with girdle stage 5 trans coming soon. line x bed liner,extang trifold toneau,edge cts, allison deep pan with transynd fluid suncoast filter lock. |
| Duramax Forum Supporter ![]() Join Date: Nov 2010 Location: Atoka,TN
| Welcome to the DF and good luck !
__________________ Bob2006 Sierra 2500HD, SLT, 4x4 CCSB LBZ, Leveled w/NITTO ALL-TERRAIN 285/75R16,Linex,Undercover Tounneau cover, diamond-eye quite tone front pipe, 4inch cat-back MBRP,Bilstein 5100's.Curt class v hitch.DSP 2 from Idaho Rob at ATP, ADP Cat filter,Firestone Ride Rites 2012 Primetime Lacrosse 318BHS www.trollperformance.com |
| DuramaxForum n00b Join Date: Sep 2012 Location: Greenville, NC
| ^^^ def what he said should be your first choice and let all connections stay open and dry for a few days
__________________ 2004 duramax 2500 lb7 14" cst suspension lift 395/85R20 goodyear mv/t (46") 20x10 ultra motorsports chrome wheels built Allison trans 5" mbrp exhaust into dual 6" mbrp stacks ![]() Injectors/Air raid air intake EFI live by southern styles diesel performance w/dsp5 switch 20 mpg with 46" tires didnt come easy ![]() |
| Junior Member Join Date: Jul 2012 Location: WACO, TX
| How long was it wet and how long has it been since its been wet?
__________________ Lane 92 3500 DRW single cab, NV4500, 3.73, 190,000 on truck, 15,000 on rebuild. Diamond Eye 3" to 4" straight pipe. 02 2500HD Allison CC LWB 4x4 171,000 Just installed its 3rd set of injectors, efi live with dsp5 switch, much more to be done... 09 Silverado CC gasser 132,000 SOLD |
| | eBay Motors #7 (permalink) | |
| Quote:
I dont know the exact way the truck got wet. I can see some water stain about 4-5" high off the floorboard on a sub woofer box on the drivers side under the rear seat. The stain doesn't go over to the other side though. Weird..??
__________________ 2002 Chevy Duramax-Crew Cab 4x4 SB IT RUNS!! Last edited by Cowansauto; 10-28-2012 at 09:48 PM. | |
| Junior Member Join Date: May 2012 Location: San Antonio, TX
| maybe he was trying to drive through a creek or a tank and only got that side of the truck in the water?
__________________ 2002 chevy silverado with the duramax and allison trans. Leveling kit 285/75/R16 BFG A/T efi live (duramax tuner pre tuned ecm) edge cts insight ppe boost valve 4 inch turbo back mbrp exhaust |
| DuramaxForum Enthusiast Join Date: Apr 2012 Location: Pittsburgh Pa
| Welcome to the forum
__________________ 2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again. 2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ. |
| DuramaxForum Fanatic Join Date: Oct 2010 Location: Maryland
| Welcome to the DF! Sent from my DROID RAZR
__________________ Donnie 08 GMC Sierra 2500HD cc/sb Debadged AFE CAI and mouth piece with resonator delete 5in straight pipe Profab Downpipe EFI live tuned by Rob at ATP PVC reroute Bank 3in IC pipe PPE Race Vavle & Ported Fuel Rail Fitting CP3 High Flow Feed Line Kit Raptor 150 lift pump built trans by Big Dipper EGR delete with 3in Y-bridge BD manifold Tinted tail lights & 3rd brake light Recon smoked LED cab lights LED tailgate bar Big Rig amber running lights 8K hids lows & driving Fuel Hostage rims Nitto 420's 305/50/20 3in drop shackles traction bars PPE straight centerlink Rareparts tierods Rancho steering stablizer and shocks line X Bed liner billet fuel door http://www.atptrucks.com/ |
