Boost leak/ Whooshing sound/Broken Up Pipe? - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Duckinator
post #1 of 8 (permalink) Old 11-04-2012, 08:03 PM Thread Starter
Duckinator's Avatar
So, running around town today, heading home There starts sound that isn't familiar. Sounds like an air compressor/vacuum when the turbo spools. I checked the boost gauge and normally up here I get mid 20's. Now it barely makes 20psi. I checked the pass side intercooler piping and pulled the drivers side to check for holes/wear. Nothing. Now I'm thinking it might be an up pipe seeing as the sound is like right down in front of me/in the footwell. Any ideas?
Thanks.
3/6 likes this.
'03 Chevy CCSB LB7 "SleeperMax"
227K mi. - EFI by Kory, AirDog II, S&B Intake, and... other not-Stock things..
Went boom 4-12-13 8:32pm
130K engine went in and running 5-10-13
Duckinator is offline
post #2 of 8 (permalink) Old 11-06-2012, 03:06 PM Thread Starter
Duckinator's Avatar
*bump*
post #3 of 8 (permalink) Old 11-06-2012, 04:45 PM
jacked-up_redneck's Avatar
Check the up pipes where they connect to the manifolds and where it connects to the turbo pedestal, and where the turbo mounts to the pedestal. Did you check all the boots our just the ones on the intercooler?
DD: 2002 gmc lb7 ccsb, 6" rcd lift, rolling dunlop mts, 5" mbrp turbo back, efi live by idaho rob, banks cold air, Airdog 150, Ppe oil centrifuge, Udp fuel filter adapter with 1 micron filter, Ppe boost valve, Profab dp, manifolds/up pipes, and intake horn, Custom trac bars, bt diesel works tapshift, batmowheel
jacked-up_redneck is offline
post #4 of 8 (permalink) Old 11-06-2012, 07:58 PM Thread Starter
Duckinator's Avatar
Duramax Boost Lost - YouTube
Made a video trying to illustrate the problem. Whats odd though is that there is no more black smoke than there was before, no external leaks that I can find, and no major loss in performance/boost.
P.S- I normally boost about 20-22psi up here. Dropped to about 16/18psi after this happened...
*head scratches*
post #5 of 8 (permalink) Old 11-06-2012, 08:01 PM Thread Starter
Duckinator's Avatar
I pulled the driver's side pipe and boots, all looked good. The Pipe had rubbing marks/dents but nothing that looked like a hole.
Just visually checked the pass side pipe/boots. Nothing there.
post #6 of 8 (permalink) Old 07-11-2013, 10:01 AM Thread Starter
Duckinator's Avatar
Turns out that where the fuel junction block bolts to on top of the intake manifold, there's two studs/bolts that go there right into the manifold. one was missing and allowing boost pressure to escape. Ran a bolt down into the hole and cured the problem.
post #7 of 8 (permalink) Old 08-16-2013, 05:16 AM
On my way in to work this morning I had the same thing happen to my LBZ, there was an intense sound of air rushing on the drivers side that i didn't notice before... Just like you, i didn't notice any loss in power or increase in smoke. I wonder if it could be the same thing...
Can you give a better description of where the missing bolt was and how you figured it out? I am planning on pulling tonight at the fair but I would like to figure this out so I don't have worse issues...
2006 Chevy Duramax LBZ Crew Cab Short Bed LT
EFI Live DSP5 tune by Idaho Rob, Suncoast Stage V tranny, Suncoast 1056 torque converter, S&B Cold Air Intake, MBRP Single SS 5" Exhaust, MBRP 5" SS Delete Pipe, MBRP 6" Black Tip, Diamond Eye Down Pipe, Tow Mirrors, Debadged (Except For Allison/Duramax), Amsoil Synthetics, DDM Tuning HIDs High 8500k, Lows 6500k. Fogs 4500k, Westin Ultimate Black Powder Coat Bull Bar, Back Rack, Line-X Over the rails, All season diesel performance steering stabilizer (pitman and idler support), tie rod sleeves
tfskidoo is offline
post #8 of 8 (permalink) Old 08-16-2013, 06:04 AM Thread Starter
Duckinator's Avatar
I dont know if the LBZs have it, I only believe the LB7s have that junction block, but dont quote me on that..
#17 in this image is what happened to mine.. It was just flat out gone..
