fuel filter change won't prime - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 11-08-2012, 02:06 PM Thread Starter
Just changed the fuel filter been trying to get the truck to prime. I've been pushing the primer pump and i'm not getting any fuel,I'm getting some air out but no fuel. I took off the filter and pushed on the primer pump and no fuel came out.
Pat
03 2500hd ccsb 185k miles, cai superchips programmer
96 E350 4x4 Draggin Wagon
huntman is offline
post #2 of 25 (permalink) Old 11-08-2012, 02:10 PM
duramaxallison's Avatar
how much fuel is in the tank?
2003 LB7 2500HD ECSB
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-35w AGT 6000k HID's
-5% tint allaround
-285/75R16 Michelin LTX A/T 2s
-340k miles and counting
-Daily Driver
duramaxallison is offline
post #3 of 25 (permalink) Old 11-08-2012, 02:11 PM
Did the O-ring stay in the right spot. Usually my o-ring wants to pop out. Maybe your did and you didnt notice? And now its not seated all the way?
Or sometimes it takes a while to get fuel out.
2006 Silverado CCSB LBZ
1995 Tahoe (Off Road Truck)
1984 Monte Carlo
1969 Camaro (Still in the Works)
Wantamax is offline
post #4 of 25 (permalink) Old 11-08-2012, 02:13 PM
also make sure the water drain didnt come loose on the bottom of the water in fuel sensor.
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-5% tint allaround
-Daily Driver
post #5 of 25 (permalink) Old 11-08-2012, 02:25 PM Thread Starter
O-ring is in correctly, water drain is in and tight. Been pumping for hours and no fuel it is sitting uphill in driveway, could that be why
Pat
huntman is offline
post #6 of 25 (permalink) Old 11-08-2012, 02:35 PM Thread Starter
Can I run a vacuum bleeder to the bleeder screw and pull the air out that way? Forgot over 1/4 tank of fuel.
Pat
huntman is offline
post #7 of 25 (permalink) Old 11-08-2012, 02:42 PM
If its a steep hill with only 1/4 tank it could be that. I would say try moving it to level ground but I'd hate for it to be stuck at the bottom of the driveway.
Maybe put more fuel in the tank?
Also, did you put any fuel in the fuel filter before you put it on, or did you install it empty then start pumping the primer?
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-5% tint allaround
-Daily Driver
post #8 of 25 (permalink) Old 11-08-2012, 02:47 PM
Like stated above try filling the filter with fuel then starting. You might get lucky that way
Sent from my DROID RAZR using AutoGuide.Com Free App
2004 GMC Standard Cab LLY
AFE intake, AFE turbo mouthpiece, pvc re-routed, profab egr delete, 4" stainless flopro exhaust, Nicktane with CAT, EFI live by ATP trucks, edge insight CTS for gauges
jwang04lly is offline
post #9 of 25 (permalink) Old 11-08-2012, 02:49 PM Thread Starter
First put it on empty thought i had the air out, started it ran 3 seconds and stopped then I pulled off filter and it was empty, put fuel in filter and reprimed it. I'm getting air out but not any fuel.
Pat
huntman is offline
post #10 of 25 (permalink) Old 11-08-2012, 05:17 PM
You filled it full to the top? It still sounds like you are getting air through somewhere, such as the hill issue. If the fuel is at the back of the tank the pickup will just suck air and you will just suck air through the system. I would try it on level ground, but irk how steep this hill is?
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-5% tint allaround
-Daily Driver
