2001 Duramax Diesel in oil, Major leak - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 11-12-2012, 07:20 PM Thread Starter
I was looking for some info on this forum and have seen many posts but cant find one exact answer so was seeing if anyone could help me. I have a 2001 Chevy 3500 6.6l 4x4 dually with 236k miles. We replaced the injectors in truck about 30k miles ago with i believe upgraded 50hp injectors. I have a KN intake, EDGE programmer (but has been off truck about 5k miles) and straight pipe exhaust. Everything has been fine with the truck but the other day I kept smelling something and noticed I hadnt driven far and my fuel gauge and dropped a bunch. I put fuel in truck and noticed that there was fluid dripping and covered almost the whole motor. I left station trying to make it home and noticed my oil pressure had dropped. I went to walmart and bought 2 gallons of oil to put in it. When I got back outside it had a huge puddle under it. I put the oil in and could see it steadily leaking. I drove the truck home 20 miles and it didnt leak near as much when i checked the next morning. I took the truck to get oil changed today and they said it was almost all diesel fuel. At the time of it messing up I had a 24 ft livestock trailer on the back and didnt notice any loss of power. Ive read it could be injectors again, injector seal or injector cup. Does anyone have any advice so I dont get screwed taking it somewhere to have the truck fixed? Thanks in advance. Blake
Uniquemotorsportz is offline
post #2 of 16 (permalink) Old 11-12-2012, 07:56 PM
Brent@LDS's Avatar
Sounds like a cracked body on an injector or return line leaking. I would get the balance and return rates checked right away before you drive it any more.
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
Click here For,
LB7 Injector Install Instructions
Brent@LDS is offline
post #3 of 16 (permalink) Old 11-12-2012, 08:30 PM Thread Starter
Do I have to get balance and rates checked at dealer? Can they tell me which one is bad? I read if you pulled covers you would be able to tell which ones were leaking with it running? Do you know anything about this?
post #4 of 16 (permalink) Old 11-12-2012, 08:44 PM
Brent@LDS's Avatar
Snap On scanner, tech 2 or some of the programmers will be able to give you balance rates. You also can run the truck with the valve covers off so you can track down the leak.
Phone: 920-361-7700
Click here For,
post #5 of 16 (permalink) Old 11-12-2012, 08:51 PM Thread Starter
ok we will try that, thank you!
post #6 of 16 (permalink) Old 11-13-2012, 03:33 PM
Exactly what my truck did, pushing fuel out everywhere.
Replaced the injectors and all is well. How did they only last 30k miles?????
2003 LB7 ZF6
Powertrain
-EFI Live Tuning, Southbend DD Clutch, Edge CTS, Banks Ram Air Intake, Banks 5" Exhaust, FASS 150, Banks Big Head Wastegate
Chassis
-Pro Comp Lift, 20X12X33, Tie Rod Sleeves,
Other
-Cowl Hood, Bull Bar, Tonneau Cover, Cab Lights, HIDs, Full Custom Stereo System
Fender13Bender is offline
post #7 of 16 (permalink) Old 11-13-2012, 03:46 PM Thread Starter
Im not sure, thats what made me think it may not be injectors. They only reason we replaced them in the first place was bc there was a little white smoke at idle. Nothing bad at all. Im just stumped on this, and dont know why they wouldnt last long at all.
post #8 of 16 (permalink) Old 11-13-2012, 04:02 PM Thread Starter
If i do replace injectors, what brand should I use?
post #9 of 16 (permalink) Old 11-13-2012, 04:03 PM
Banned
Genuine Bosch remans. From Lincoln diesel
ferdkila is offline
post #10 of 16 (permalink) Old 11-13-2012, 04:06 PM Thread Starter
I know there are problems sometimes with reman. parts. I have bought a few things reman from advance auto and the part wasnt good and had to take it back off and get another. That would be a pain in the ass with injectors.
