| Senior Member Join Date: Oct 2012 Location: Celina, TX
| ordered parts, what else do i need so i just ordered a set of bosch injectors and install kit, arp head studs, injector cup orings and head gaskets. i was going to order all new injector cups but decided to wait till i get it apart to see how they look. Can anybody think of anything else i will need gasket wise, o rings, etc. Thanks in advance for any info
__________________ 2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust. Soon to come: Built trans, Built motor, and twins http://www.trollperformance.com/ |
| juss some more info i left out i will be replacing injectors and head gaskets next week and juss wanting to know what else i need to complete this installation
| Duramax Lifetime Supporter Join Date: Nov 2012
| make sure you use the correct head gasket thickness so theres no interference with the piston. good luck
__________________ 2002 C3500 LB7 300,000 miles and going, all stock, used to pull horse trailer and work around farm. |
| i ordered the grade c from merchant automotive. Are those correct?
| Junior Member Join Date: Nov 2012 Location: Bowling Green Ohio
| Subscribing. Gonna be doing this in the near future as well.
__________________ 01 Cummins QCLB 5sp 4x4: Some air, More fuel, Supporting mods, and a little bit of spray ![]() 01 LB7 CCSB 4x4: Work in progress. |
| update: just ordered exhaust manifold gaskets, up pipes to manifold gaskets, lower valve cover gaskets, and Y-bridge seals. Somebody told me i need a turbo coolant hose..do i really need that?
| need to measure the piston protrusion height and select approp. gasket Cylinder Head Gasket Grade Gasket Grade Projection Value Gasket Thickness A (No hole) Over 0.223 to less than 0.274 mm (0.0088 to less than 0.0108") 0.90 to 1.00 mm (0.0354 to 0.0394") B (One hole) Over 0.274 to less than 0.325 mm (0.0108 to less than 0.0128") 0.95 to 1.05 mm (0.0374 to 0.0413") C (Two holes) Over 0.325 to less than 0.376 mm (0.0128 to less than 0.0148") 1.00 to 1.10 mm (0.0394 to 0.0433")
| Junior Member ![]() Join Date: Apr 2012 Location: Canon
| Be sure and check your cup/sleeve seat on the head for corrosion. Sometimes can't see it, gotta feel it.
__________________ '02 Silverado 2500HD LT White, Grey Leather, 4X4 ![]() Keep your powder dry! I'm sorry for you Rand, you've worked so hard to learn so many things so badly. |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| Quote:
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods | |
