| Junior Member Join Date: May 2012 Location: Imperial, PA
| Low Operating Temp - No P0128 Code So I have been scouring the board over the past couple of days and posting to get some answer with this issue. It seems that I am not the only one that is having the low operating temperature issues now that the temperature is dropping as we head into winter. A quick run down of what I have happening is that the truck will not hold a normal operating temperature when the temperature is below about 60 degrees. It typically runs at about 176 degrees and doesn't take abnormally long to get up to that temperature. It will struggle to hold the 176 degrees though and fluctuate between about 170-180. When the temperature gets into the 180 it will drop like a stone as soon as I get off of the throttle. My first thought was to throw the winterfront grill cover on the truck which has had a negligible impact on the temperature. So I am left with believing that one of the thermostats is stuck open. However, I am not getting a P0128 code which I should be getting if that was the case. I'm not sure If I should just replace the thermostats anyway to be sure that they are not the problem. What other issues could be causing the low operating temperature? I know that the LB7s are quite the cold-hearted engines but if the thermostats are set to open at 180 and 185 then running at 176 with the thermostats functioning correctly would mean that coolant is not circulating at all. However, the upper radiator hose is always warm after driving, not scalding hot but warm and the hose itself isn't hard. Any ideas or thoughts, should I just change out the thermostats and bleed the system to check for air pockets. Or is this just a normal LB7 in the winter time?
__________________ ![]() '03 ECSB Silverado 2500HD aka Allie Diesel EFILive Tuning by Kory Willis - Edge CTS Insight w/ Pyro - PPE Boost Valve - MBRP 5in exhaust - Modified Intake w. K&N Filter |
| Duramax Lifetime Supporter Join Date: Nov 2012
| i just got back from the duramax school in atlanta a few weeks ago and we talked about thermostats and if you replace them make sure they go in the proper location, there are two and it makes a difference which one goes where. one of the side effects of improper locaton is slow to get to operating temp due to the coolant bypassing when it should be holding in the engine. now i also know that when in the shop we can let a duramax run till your tired of hearing it and it will never reach operating temp to run some test that we have to run, so yes they are slow to heat at low power settings.
__________________ 2002 C3500 LB7 300,000 miles and going, all stock, used to pull horse trailer and work around farm. |
| Senior Member Join Date: Mar 2009
| I don't know how cold you are, but I never had this issue with my LMM, or LML. Only when it was -30 -40 -50c would idle temps drop. LML is much better. But I'd drop down to 75c with leather front. Sent from my Autoguide iPhone app
__________________ 2012 Chevy 3500HD LTZ, Crew Long, Z71, H&S Minimaxx, DE downpipe, 5" Flo~Pro DP back exhaust, 275/70/18 Mickey Thompson ATZ on Fuel Krank Blacks, White Line-x rocker panels, white line-x Bushwacker pocket flares, DDM Tuning HIDs 4500k, 35W/35W/55W, Custom JetCraft sled deck, Nathan K3LA, Onboard air, Viair 400c/444c compressors. |
| | eBay Motors #4 (permalink) | |
| Quote:
__________________ ![]() '03 ECSB Silverado 2500HD aka Allie Diesel EFILive Tuning by Kory Willis - Edge CTS Insight w/ Pyro - PPE Boost Valve - MBRP 5in exhaust - Modified Intake w. K&N Filter | |
| I found my answer: The ECM is calculating an expected Coolant Temp given the fuel that has been burned and the time that it has been burning it. If the coolant temp does not meet or exceed the calculated temp, you get the code. Check for proper coolant level. Perform Coolant System Leak Test. Inspect fan for proper operation. Inspect the fan belt to ensure it is in good operating condition? Remove thermostats and verify proper operation. Bring to boil in a pot of water and see what temps they open and close at. Start opening ~ 160 Fully open at ~ 180 Degrees F roughly. Could also be a bad ECT Sensor. You can do a resistance check at various temps. At 0 degrees F Res = 9420 ohms At 50 degrees F Res = 973 ohms at 100 degrees F Res = 177 ohms, at 150 degrees F Res = 47 ohms. This condition could also be caused by air in the coolant system. That could possibly be an indicator of a bad head gasket. After shutting the warmed engine off, and letting it set for several hours, check the upper Rad hose to see if it is hard. If it is hard, you probably should test for a headgasket failure.
| I just wanted to add some closure to this thread. I swapped out the thermostats tonight and immediately my truck held 181 degrees while driving. Sent from my iPhone using AutoGuide.com Free App
