| Senior Member Join Date: Mar 2012 Location: Jurupa Valley, Ca
| Where did you read about head gaskets blowing after a water pump replacement?
__________________ 2003 Chevy Silverado 2500HD CC SB Duramax Airaid Intake, 4" Cat Back Jardine Exhaust, '06 Tow Mirrors, Husky 24k Slider Hitch, Tekonsha Prodigy, Billet Grill, Injectors Done at Dealer at 125k...now has 157k, UltraGauge Nicktane Adapter and Donaldson filter on its way |
| Senior Member Join Date: Dec 2008 Location: Coldwater, MI
| There are multiple threads on here guy replaces water pump head gaskets blow.... Not saying it is all the time but it has happened. Sent from my iPhone using AutoGuide.com App
__________________ 01 LB7 ECSB DSP5 MA Trans. Custom Straight pipe Autometer Cobalts 20" 027's EFI Live by PPEI. Sold 07.5 LMM RCLB DSP5 by Idaho Rob, 4inch Straight pipe, Edge Insight CS.... More to come Sold 04 GMC LB7 Crew Cab EFI Live Autometer Carbon Fiber Gauges 4" MBRP exhaust |
| | eBay Motors #13 (permalink) |
| DuramaxForum Veteran Join Date: Aug 2009 Location: Northern VA
| How To: Replace Water Pump in 1hr:) Took me a lil over an hour, get the lisle tool, saves unnecessary work, and with a real long extension and swivel you can get to the water tube on the back of the pump and you don't have to remove the t-stat housing, you can slide it in. OP where do you live? Also the dealer quoting about a grand is right, it calls for like 8 hours in the book.
__________________ 2003 2500HD LT CCLB, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, Edge CTS, Cognito UCA, Rare Parts Tie Rods, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, PPE Level 2, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air ![]() http://www.trollperformance.com/ You know you want too |
| | eBay Motors #14 (permalink) | |
| Senior Member Join Date: Nov 2010 Location: Ogden Utah
| Quote:
__________________ 2001 EC/SB S475 batmo. Tuning from ?. Trans from EPR 4 inch exhaust. Raptor Traction Bars. 510hp 1244 tq uncorrected. Stock Turbo, injectors,cp3. 13.02, Stock turbo, injectors, cp3. http://www.trollperformance.com/ | |
| | eBay Motors #15 (permalink) | |
| Quote:
__________________ 2003 Chevy Silverado 2500HD CC SB Duramax Airaid Intake, 4" Cat Back Jardine Exhaust, '06 Tow Mirrors, Husky 24k Slider Hitch, Tekonsha Prodigy, Billet Grill, Injectors Done at Dealer at 125k...now has 157k, UltraGauge Nicktane Adapter and Donaldson filter on its way | |
| | eBay Motors #16 (permalink) |
| DuramaxForum Veteran Join Date: Aug 2012 Location: Youngsville/Wake Forest
| I think it's a coincidence. Or they were blown before the pump was replaced and the leak in the system didn't show any symptoms. Sent from my iPhone using AutoGuide.com Free App
__________________ 2004.5 Sierra SLT 4WD CCSB Black/Black Studded, Deleted, Re-Routed FPRV Race Valve LBZ FPR 20x10 ET -12 Fuel Hostage Nitto 420s 305/50/20 All-On Mod MA Pump Rub Kit 3" DE Down Pipe to a 7" Single Mitre Cut EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI |
| | eBay Motors #17 (permalink) |
| Parts wear out! Head gaskets blow and the water pump wears out on all vehicles. No connection. Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App
| | eBay Motors #18 (permalink) |
| Junior Member Join Date: Mar 2011 Location: Butler, PA
| I didn't know mine were blown intil I changed my waterpump. Coincidence maybe???
__________________ 05 EC/SB Sierra SLT Rerouted, AFE MP, 5 Inch D.E. Str8 Pipe, pro fab dp, Edge CTS, EFI by Rob, Sleeves, ported fuel rail fitting, ARP headstuds and grade C gaskets, Leveled on black H2's with 285's. Future Plans: Trac Bars, Lift Pump Tyler @ www.meyerperformance.com |
| | eBay Motors #19 (permalink) |
| DuramaxForum n00b Join Date: Jan 2012
| I expect the water pump fails sometimes due to the build up of pressure instead of coming out of the rad. reservoir. It finds the weakest point and thats why it leaks out of the water pump is my guess to all this. I just hope I don't find that the headgaskets are blown. Is there a test I could do? |
| | eBay Motors #20 (permalink) |
| ^^^ that is kind of the general reasoning it seemed in the threads I read. When my head gaskets were out the top radiator hose was hard after sitting all night and you couldn't remove the reservoir cap without it blowing coolant everywhere. Sent from my iPhone using AutoGuide.com App
