Water pump Needs to be replaced help!! - Chevy and GMC Duramax Diesel Forum
Old 11-15-2012, 03:19 PM   eBay Motors  #1 (permalink)
I have an 04 LB7 with 165,000 mi on it and just the other day my dash said I had low coolant. After checking it out I found the water pump seemed to be leaking.. leaking I mean there was orange crust on the bottom and looked as if the coolant had run down some of the hoses. The shop wants about $1000 but I am half tempted to do it my self. Any thing in particular that I need to be careful of or need to do before I start. Also what brand water pump is the best for these trucks and about what price ranges should I be looking at for the water pump its self. Thanks for your help guys
CharlestonFF is offline   Reply With Quote
Old 11-15-2012, 03:30 PM   eBay Motors  #2 (permalink)
red1977's Avatar
I paid a shop 400 to do mine. That's parts included.
2001 EC/SB
S475 batmo.
Tuning from ?.
Trans from EPR
4 inch exhaust.
Raptor
Traction Bars.
510hp 1244 tq uncorrected. Stock Turbo, injectors,cp3.
13.02, Stock turbo, injectors, cp3.
http://www.trollperformance.com/
red1977 is offline   Reply With Quote
Old 11-15-2012, 03:41 PM   eBay Motors  #3 (permalink)
Super Moderator
jc1843's Avatar
The hardest part about changing the pump-- is removing the balancer -- and then retorquing it to 265 lb ft. Leslie makes a flywheel tool and special 36 mm 12 point balancer bolt socket to help-- and you need a 3/4 breaker bar and an energy drink.
There is also a lot of parts to remove and reinstall.
Old 11-15-2012, 03:41 PM   eBay Motors  #4 (permalink)
e46_330i's Avatar
You got a deal. An OEM pump is going to run you $170-200 and the shaft should be welded. I got mine for Merchant with the shaft welded for like $170 I think.
2004.5 Sierra SLT 4WD CCSB Black/Black
Studded, Deleted, Re-Routed
FPRV Race Valve
LBZ FPR
20x10 ET -12 Fuel Hostage
Nitto 420s 305/50/20
All-On Mod
MA Pump Rub Kit
3" DE Down Pipe to a 7" Single Mitre Cut
EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI
e46_330i is offline   Reply With Quote
Old 11-15-2012, 03:54 PM   eBay Motors  #5 (permalink)
I haven't heard of a balancer? is that on the fan I am guessing? So that needs to be torqued to 265lbs? I know you have to take off the starter and put a socket or something to keep the flywheel from spinning is that to take off the fan and all?
Old 11-15-2012, 04:06 PM   eBay Motors  #6 (permalink)
dieseladdiction23's Avatar
Balancer is on crankshaft, u have to remove it because one of the water pump bolts is behind it
2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust.
Soon to come: Built trans, Built motor, and twins
dieseladdiction23 is online now   Reply With Quote
Old 11-15-2012, 04:07 PM   eBay Motors  #7 (permalink)
I didn't remove starter when I did mine
Old 11-15-2012, 04:08 PM   eBay Motors  #8 (permalink)
e46_330i's Avatar
No need to remove the starter if you get the Lilse tool. I ordered my pump from Merchant as well as the tool. Best price around!! And the customer service is bar none. Technical support is the owner, Eric Merchant. Can't beat that.
FPRV Race Valve
LBZ FPR
All-On Mod
MA Pump Rub Kit
Old 11-15-2012, 04:08 PM   eBay Motors  #9 (permalink)
Srry leaving stuff out lol, there's a place to put a flywheel holder on the back of the engine
Old 11-15-2012, 05:48 PM   eBay Motors  #10 (permalink)
So I have been doing some reading up on this. Did yall have issues with head gaskets blowing after you replaced your water pump? How bad is it to drive around with a water pump that is leaking? One more question and Im done is there a good place to go to read up on directions on how to replace the water pump your self. Sorry for all the questions Im trying to save money and don't want to pay the dealer a lot of money!
