HELP! no start after cp3 replacement - Chevy and GMC Duramax Diesel Forum
Old 11-16-2012, 07:32 AM   eBay Motors  #1 (permalink)
Unhappy HELP! no start after cp3 replacement
2500 hd 01 lb7 175,000 miles
all stock except 6in lift (no programmer anymore)
ok so truck was running good except i had tested the pump about a month ago an pump only put out 17,000 psi and would go into limp mode at like 65-70 mph i kept my scanner in my truck and have just been clearing codes when i drive. anyways i replaced the pump last week, and no the truck wont start, and wont prime?!?!? heres the checks i have done:
-no engine codes while cranking
-pumped primer and pushed schreder valve in and bled alot of fuel and and some air out the lines
-kept pumping the primer but never got stiff!(i had to do this before a few months back when i pulled the pump to change the fpr) and it got stiff
-cranked the truck during priming(nothing)
-cracked line after pump and pushed the primer in and had fuel coming out after pump
-tried starting it on wd-40 but i was by myself and had to spray then jump in and try starting(didnt start)
also afte i push in the schreder valve after bleeding the air and fuel out, it builds up some pressure again and when i bleed again it shoots fuel across the room so i believe my primer is still working correctly
then right after im pumping it almost sounds like i have air escaping from around the filter area i believe not sure tho. (someone before me had removed the primer bleed screw i believe because the area where my bleed screw is suppose to be in a small bolt with a bunch of washers stacked up?!?)
i have tried everything from what i been reading online and have called diesel shops and they gave me a few of the things i mentioned above to try but still no luck. truck is at a performnance shop now but they havent touched it all week and im fed up about to trailor it out of there i am a mechanic but still going to school for it i do have experience but thisis the first diesel i have messed with!
*i read somehting yesterday about loosening the bleed screw a few turns then priming the fuel but it worked without doing so last time a had to do this and truck ran good before i did this just didnt have much power and is getting bad fuel economy i believe due to the weak cp3 so any advice would be helpful!!!
(sorry for the long post just trying to get all info out there)
Camokid09 is offline   Reply With Quote
Old 11-19-2012, 07:24 AM   eBay Motors  #2 (permalink)
bump...any ideas????
Old 11-19-2012, 09:57 AM   eBay Motors  #3 (permalink)
Only 80 psi during cranking!!!! Any ideas
Old 11-19-2012, 11:09 AM   eBay Motors  #4 (permalink)
04lb7zf6truck's Avatar
run a rubber hose and by pass your filter housing and see if it starts...
Wes--2004 Chevy 2500HD 4dr CCSB
The goodies.....zf6 valair DD/carrillo rods,arp main studs and head studs,75% injectors, comp cam....20 inch BMF Novakane/Trail Grapplers....Evan Davis Tune..Just enough stuff to turn heads at the grocery store
04lb7zf6truck is offline   Reply With Quote
Old 11-19-2012, 12:57 PM   eBay Motors  #5 (permalink)
Ill check that tonight what does it mean if it starts after that?
Old 11-19-2012, 01:09 PM   eBay Motors  #6 (permalink)
From what i have read it would mean your filter housing is cracked or need the o rings replaced in it.
Old 11-19-2012, 01:09 PM   eBay Motors  #7 (permalink)
Or you could have a bad fuel leak somewhere or a pinched line
Old 11-19-2012, 02:26 PM   eBay Motors  #8 (permalink)
Not a fuel filter housing or primer issue with tank pressurized steady stream
Coming out of bleeder what else would cause my primer not to get stiff and the rail pressure not to get over 130 psi
Old 11-19-2012, 02:33 PM   eBay Motors  #9 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
Unplug the FPR wires and try to start it. It will make the CP3 work at 100%, and create 100% rail pressure. It will lope hard if it starts, But it's an idea. Or you can try to pressurize the tank with about 10psi and try starting the truck. It may help the CP3 prime itself. Because it sounds like the CP3 isnt priming itself for some reason.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is offline   Reply With Quote
Old 11-19-2012, 03:30 PM   eBay Motors  #10 (permalink)
tmm403's Avatar
Subscribed
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids
tmm403 is offline   Reply With Quote
