glow plugs - Chevy and GMC Duramax Diesel Forum
Old 11-21-2012, 02:10 PM   eBay Motors  #1 (permalink)
glow plugs
Do the California LB7s have the same glow plugs as the Federal? I have a California truck, what type/brand glow plugs do you all recommend? Thanks.
2002 2500HD CrewCab shortbed. All stock except lift and 35s.
jeepwcrazy is offline   Reply With Quote
Old 11-22-2012, 12:39 AM   eBay Motors  #2 (permalink)
Ok, so after playing around on the internet, this is what I found.
Glow PlugsAll Duramax engines use one glow plug per cylinder. The gold-colored LB7 glow plugs are 12-volt heaters that are energized prior to starting the engine, and they may also be operated for a short time after the engine has started (up to 30 seconds). The LLY, LBZ, and LMM engines use silver-colored glow plugs and operate on 4.7 volts.
To meet 2001 California emissions, a solid-state glow plug controller operated by the ECM had dominion over heating each cylinder separately.
During typical glow plug operation, 110-amp current is applied for 1.8 seconds, decreasing to the 30 amps that are necessary to keep the tip at 1,832 degrees F.
The silver (LLY) and gold (LB7) glow plugs can't be interchanged. Use of the gold glow plugs in place of the silver will result in hard starting due to a lack of heat. Using the silver glow plugs in place of the gold will cause possible failure to the glow plugs, cylinder head, and internal engine damage.
Read more: Duramax Diesel Electronics - Diesel Tech - Diesel Power Magazine
So what I take from the above is as long as its a gold glow plug I should be good. And the reason I originally asked the question was that I went on RockAuto to look at pricing and I saw a $31 glow plug that stated California Diagnostics so I guess my next question would be, what does that mean and do I need that?
Old 11-22-2012, 07:25 AM   eBay Motors  #3 (permalink)
RichieRich's Avatar
Good info
2003 Chevy Silverado 2500HD CC SB Duramax
Airaid Intake, 4" Cat Back Jardine Exhaust, '06 Tow Mirrors, Husky 24k Slider Hitch, Tekonsha Prodigy, Billet Grill, Injectors Done at Dealer at 125k...now has 157k, UltraGauge
Nicktane Adapter and Donaldson filter on its way
RichieRich is offline   Reply With Quote
