| Junior Member | loud knocking/smoking e-way breakdown This truck is killing my trust. 2004 LB7 8 injectors done in 2010 Cyls 1,3,5,7 done in 2011 Thanksgiving day i passed a vehicle and noticed a puff of black smoke. I get off the gas and its knocking. Bad. Instantly knocks upon startup and is not driveable. Chugs black smoke too. No codes are being thrown. Truck got towed 150miles and is now at the diesel shop. Any suggestions?
__________________ Last edited by 87sheerips; 11-25-2012 at 05:03 AM. |
| Banned Join Date: Jan 2010 Location: On the Coast of Somewhere Beautiful
| Balance rates checking out? |
| Junior Member |
__________________ |
| Moving to LB7-- truck is in shop.
| The FICM balances the injectors to keep down harmonic vibrations in the crank. If an injector is going bad the rate at which it injects fuel is compromised and the FICM will pull or add fuel to try and keep the crank balanced. Anything + or - 4.0 is considered out of spec and needs to be replaced. Have the shop tell you the balance rates... |
| | eBay Motors #6 (permalink) | |
| Junior Member | Quote:
Should I look into such things as the harness shorting out around alternator and/or the ice pick trick?
__________________ | |
| DuramaxForum Enthusiast Join Date: Apr 2012 Location: Pittsburgh Pa
| Did you put remans or did you get new injectors. And are they bosch s
__________________ 2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again. 2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ. |
| Junior Member Join Date: Oct 2010
| mine did the same thing but my injection pump blew up throwing metal shavings into my injectors causing the injectors not to fully close
__________________ Truck: 2008 Chevy Silverado 2500 Motor: EFI Live tuned by Rob, Air Dog 165, Ported fuel rail fittings, Plugged rerouted and shimmed, Snow stage 3 Mpg/max, AFE mouthpiece, Dimond eye downpipe, High flow intake, y-bridge and EGR delete, Hot side pipe, 50% injectors,42% Cp3, 4094 turbo, Big dipper trans, 4.56 gears. Interior: Edge Insight, Autometer pyro,boost,trans, Kenwood headunit with backup cam, Duha, Neoprene seat covers Exterior: RDS 75 gallon fuel tank/toolbox, EBC slotted/drilled rotors, B&W turn over ball, Maghytec diff, RX 9000 shocks with air. Fender flares Road Armor front & rear bumber and bed all line-xed color matched, Billet grille, Dual 4 inch exhaust, 6 inch lift, 22 inch wheels in nitto terra grapplers,Led smoked tails |
| Junior Member | The work was performed at a dealer thru the previous owner. Do they use a standard replacement or do you have the option of remans?
