injector cups - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 11-27-2012, 11:36 AM   eBay Motors  #11 (permalink)
boostnlb7's Avatar
well the red is high temp, which i think i would want... now a guy just told me he puts the injector in the cup, pushes injector/cup in the head by hand as far as he can, then puts the steel hold on clip and bolt in and tightens to push injector and cup down all the way.. some guys have said to push and tap cup in first then install injector..any ideas on that? anyone reading feel free to fill me in, thats why were here.. thanks
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
Old 11-27-2012, 11:58 AM   eBay Motors  #12 (permalink)
dieseladdiction23's Avatar
When I just did mine I tapped in the cup with a socket and then put injector in. Don't think it matters as long as u know u got it all the way seated
2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust.
Soon to come: Built trans, Built motor, and twins
http://www.trollperformance.com/
dieseladdiction23 is offline   Reply With Quote
Old 11-27-2012, 12:02 PM   eBay Motors  #13 (permalink)
boostnlb7's Avatar
ok..should the top of the injector cup be flush with the head or will it just bottom out? and id like to get the lock tite thing straightened out due to i will be installing cups this week and want to get the right stuff.. BTW looks like bottom of my cups have red on them.. good/bad?
Old 11-27-2012, 12:05 PM   eBay Motors  #14 (permalink)
We use the installation tool, then put the injectors in and fill coolant back up. I am sure the red works as well. Just would be concerned possibly of trying to get a sleeve back out at any time. Not sure if anyone has run into a issue with that. The green sleeve retainer we use on all dmax and powerstrokes and never have had one have a issue again. I would need to look to see if the bottle states anything about temp. The ford manual states to use it etc. So if its good enough to hold a pos ford together its good enough for a dmax lol.
2002 LB7 Crew Cab Dually,AFE Cold Air Intake,Diamond Eye 5inch Down Pipe Back Straight Piped, Edge Insight, 40% Over II Injectors,
shovelheadsteve is offline   Reply With Quote
Old 11-27-2012, 12:09 PM   eBay Motors  #15 (permalink)
U will know when the cup bottoms out, I used the red loctite high temp. I didn't know about this green stuff when I did mine
Old 11-27-2012, 12:17 PM   eBay Motors  #16 (permalink)
boostnlb7's Avatar
good point shovel head, on the pos ford thing i like that.. i have my upper rad. hose off so how much cooolant can i put in? and ive never heard of green either but from what shovelhead just stated it seems to work..how much is intall tool? and i got an idea ill put green lok tite on one bank and red on the other..hahaha
Old 11-27-2012, 12:32 PM   eBay Motors  #17 (permalink)
So guys I just grabbed my bottle. It is made by Permatex and it is called High Temp Sleeve Retainer. The part number is 64040. It has 3,000psi of holding power etc. States on the bottle that you may need heat or special tools to take back apart. You don't need the installation tool. You can take a socket that fits the top part of the sleeve and tap them in until they bottom out. Hope this is helpful. Napa, carquest etc carry it.You dont have to put coolant in for it to set up. I was thinking of something else, just like I thought it was made by loctite. Sorry brain fart lol.
Old 11-27-2012, 12:53 PM   eBay Motors  #18 (permalink)
boostnlb7's Avatar
lol alright sounds good to me, im sold.. one question will the cup extractor tool get them cups back out a year from now? or in the future i should say..
Old 11-27-2012, 02:57 PM   eBay Motors  #19 (permalink)
boostnlb7's Avatar
how do i clean the old lok tite out of the bottom of the hole in my head? just got looking into that today and can still see old lok tite in the bottom where cup seats to the head.. i dont want that stuff in my cylinders, unless its not a big deal, any info guys?/ thanks
Old 11-28-2012, 08:52 AM   eBay Motors  #20 (permalink)
You can try using a injector brush. You can buy them off of the tool trucks. They are used for the old 6.9, 7.3, 5.9 diesel to go into the injector hole and clean it. Then I have taken the end of our shop vac and duck tapped a small hose that will fit down the injector hole into the cylinder onto the shop vac end. Hope this is helpful.
