possible blown head gasket help! - Chevy and GMC Duramax Diesel Forum
Old 11-27-2012, 09:14 PM   eBay Motors  #1 (permalink)
GarrettSanchez's Avatar
The other day im towing a light load and the coolant light came on so i topped it off later on that night and ran it with the cap opened and noticed the coolant resivoir is bubbleing purfusly and with the cap on for a while warming up my upper hose is rock hard. no overheating ever or mixed fluids those are my only symptoms. pretty sure its a head gasket but wanted to see if anyone has had this problem like maybe if a thermostat stuck closed would do that or something i dont know. ANY ADVICE HELPS THANKS!
2500HD 4x4 ext. cab long bed.
PPE boost valve, S&B
RBP 4" to 5"tip, Driver side ex. manifold upgrade
New wielded water pump
Edge juice with att.
Intake heater delete
Fresh rebuilt turbo at AZ turbo and tractor
Fresh GM injectors baby. Remaned my Cyl. heads
Custom Traction arms(gotta mount)
GarrettSanchez is offline   Reply With Quote
Old 11-27-2012, 09:17 PM   eBay Motors  #2 (permalink)
mike diesel's Avatar
Bubbling resevoir and hard upper rad hose is proof enough. Headgakset time.
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
mike diesel is offline   Reply With Quote
Old 11-27-2012, 09:20 PM   eBay Motors  #3 (permalink)
i went to reliable diesel fo a quote and damn near had a hart attack they quoted over 4k. I just honestly dont fill like doing it i just was in the heads....
Old 11-28-2012, 01:38 PM   eBay Motors  #4 (permalink)
can i leave the intake and exhaust manifolds connected and get by just taking off y bridge and unbolting uppipes from manifold. i dont wanna pull the turbo again that was a nightmare!
Old 11-28-2012, 01:51 PM   eBay Motors  #5 (permalink)
blacksmokelb7's Avatar
You don't have to pull the turbo.Yes you can leave the manifolds and clams on.Better eat your wheaties that morning it's gonna be heavy.
Sent from a black cloud and the smell of burnt rubber
04 CCSB LB7 IIs483 over IIs366,carillos,cut and coated lb7 slugs,ported heads,RDL downpipe uppipes manifolds ,efi live with dsp5,Big Dipper stage 4,4 inch out the back, ram air keystone hood,US Speedoo fox racing shocks cluster,rolling on hummers,and wraped in silverbirch. And some wicked tunning from Bo-Bo (Bob Olson)
11.64 @117
Originally Posted by hllbllylmsne
Sounds like you screwed up the seat to steering wheel linkage, no real fix for it, sorry
blacksmokelb7 is offline   Reply With Quote
Old 11-28-2012, 02:26 PM   eBay Motors  #6 (permalink)
X2 head gaskets leaking
livin_4_speed is offline   Reply With Quote
Old 11-28-2012, 02:40 PM   eBay Motors  #7 (permalink)
Duramax Forum Moderator
Bonomax's Avatar
4k is sounds ridiculous high. should be around 2k. just had it done to my truck last April.
2001 GMC 2500HD EC/SB w/135k
ENGINE: ARP head studs, Danville stage 1 BMW IHI, HDi EBC, Profab 3.5" horn, Airdog 2-165 w/CAT filter, BD diesel manifold, 4" electric cut in front pipe, MBRP down-pipe, AIH and stock fuel filter deleted, banks: waste-gate, intake and super scoop
FRONT END: Super Diesel "TT" straight link package with sleeves and all moog parts.
TRANS: PPE stage 5 kit and ML-G converter w/MA pump rub kit by Caleb @ Blackout Performance
Exterior: Spec-D Tuning headlights and corner lights, recon taillights, custom bumper, custom N-Fab nerf bars, custom 03 stock grille w/APS mesh insert powder coated and lots of linex
Bonomax is offline   Reply With Quote
Old 11-28-2012, 02:43 PM   eBay Motors  #8 (permalink)
onthefritz's Avatar
X2 on eating your Wheaties. It is heavy if you do it in the truck and only one person lifts it out. Lol I know from experience!!!
I wasn't pushing fluid yet. But I had a hard upper hose. One cylinder was blown and three others were starting to blow.
If you're up for the challenge then go for it. It's a great way to learn about our trucks.
05 EC/SB Sierra SLT
Rerouted, AFE MP, 5 Inch D.E. Str8 Pipe, pro fab dp, Edge CTS, EFI by Rob, Sleeves, ported fuel rail fitting, ARP headstuds and grade C gaskets, Leveled on black H2's with 285's.
Future Plans: Trac Bars, Lift Pump
Tyler @ www.meyerperformance.com
onthefritz is offline   Reply With Quote
Old 11-28-2012, 08:23 PM   eBay Motors  #9 (permalink)
i hate working on my trucks. i do inframes on semis and there cake compared to these stupid things. at least i dont have to pull my cab
