| DuramaxForum n00b Join Date: Feb 2012
| Looking to buy 01 Duramax opinions please Well like the tittle says I am looking into buying an 01 Duramax here is the catch the truck has been sitting for about 8 months needs tires batteries interior is rough engine bay looks good for it sitting for 8 months. the guy wants 2k for it he said it was running before so no real history on it if I were to buy this truck what would be the first things to do cause I dont think I want to just put batteries in it and just try to start it ? Also if the engine is shot or any other problems/worst case scenerio drop used engine in for 4-5k ends up being a 7k truck guess what im asking is this a decent buy or pass up on the money pit? |
| Junior Member Join Date: May 2012
| my guess is that it needs more than tires and batteries, sounds like you are willing to put in the work so it may turn out to be a good deal in the long run. I would put fresh diesel in it, see if it can hold prime after changing the oil and then see what happens. |
| Would you suggest changing all fluids? should I drop the tank and clean it out?/does diesel go bad after sitting for a while? and if it does go bad how to i go about getting rid of all the bad diesel in the lines? anything else i should look at? |
| DuramaxForum Veteran Join Date: Mar 2011 Location: Huntersville, NC
| Yes, change everything you can. And yes, diesel fuel degrades over time. You mine have to drop the tank and drain the lines. Sounds like a good deal if it will run.
__________________ Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4. EFI Live by Idaho Rob, 296K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Westin steps, Bilstein Shocks, Road Master Active Suspension, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100, Nicktane w/ CAT 750, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires. ADRENALINE TRUCK PERFORMANCE APPALACHIAN COAL ROLLERS Merchant Automotive CENTRAL FLORIDA DURAMAX |
| DuramaxForum Enthusiast Join Date: Jun 2011 Location: Bellingham, Wa
| Id buy it. Worse case find a LLY motor and do a swap. Ive seen them go for around 2-3k on Craigslist near by me. How many miles?
__________________ Gideon ![]() 01 LB7 EC/SB Ally 4x4 shop ornament DD: 1990 4runner completely stock 4x4 3.slow Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel |
| got about 130k on the odemetor and how do you do a swap thought it could only be done if your lb7 was 03-04 |
| Junior Member Join Date: Jul 2012 Location: Mn
| Worst case, part the truck and make 2k back easily, a rolling chassies is easily worth over 2k, doors, bed tail gate, seats, hood, easily 2k in parts easily more then that.
__________________ 2004 LB7 Extended cab short bed 4x4 LT with EFI Live, Fass 150, AFE exhaust and Edge insight cs. |
