lb7 with air dog 150 - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 12-02-2012, 07:42 AM Thread Starter
i recently had an air dog 150 installed on my truck. didnt have the best mechanic now my truck is a pain to put fuel in. any ideas
mckenziemt is offline
post #2 of 5 (permalink) Old 12-02-2012, 07:45 AM
bamadiesel..WFO!!'s Avatar
Are you refering to it spitting out of the filler neck when filling up?
2007.5 CCSB
2003 CCSB SOLD
EFI LIVE with Max Effort from ATP TRUCKS, 5" MBRP with DPF delete, SDP EGR delete tube, S&B, PCV reroute, Airdog II 165, Fuel shim, Fuel fittings ported, Edge Insite CTS, Glowshift boost & fuel psi, Transgo Jr., BDS 4.5, Cognito UCA, Ready Lift keys, 35 x 12.5 nitto mt, 20 x 8.5 rockstars
bamadiesel..WFO!! is offline
post #3 of 5 (permalink) Old 12-02-2012, 07:53 AM Thread Starter
that is correct. it filled up fine before
post #4 of 5 (permalink) Old 12-02-2012, 07:59 AM
their is a piece that has to be put on in the filler neck and if it is backwards it will cause fuel to backup. I have the small fillerneck on mine and i took the middle small vent tube out of it. It helps fill up a little bit more but it still spits out.
If you really want to fix it for good, take off the piece and make sure he installed it with the angle of the return fitting pointing towards the tank and not the filler neck and also this would help out too.....GM fillneck kits
still have no idea why they would ever put a small filler neck on a diesel truck.....makes no sence.
2007.5 CCSB
2003 CCSB SOLD
post #5 of 5 (permalink) Old 12-02-2012, 08:16 AM Thread Starter
thanx will check this.
