| Junior Member Join Date: Aug 2011 Location: Cottrellville Twp. MI
| Control Arm Bushings I recently put 3" keys, 2" blocks, and new shocks all the way around on my truck. I went to take it in and get it aligned and they said I needed a lower right ball joint and new idler and pitman arm. So instead of replacing just them three parts I've decided I am going to replace everything in the front end. Here's the parts I already bought, all MOOG: Idler Arm, Idler Arm Bracket Assembly, Pitman Arm, All 4 Ball Joints, Inner Tie Rods, Outer Tie Rod Ends, Sway Bar Bushings, Sway Bar End Links. I also ordered the Cognito Idler and Pitman Arm Brace Kit and Tie Rod Sleves. Also got two new Timken Wheel Bearings. My question is should I replace the control arm bushings? Anything else I should replace while I am in there? Anything else I should add while I am in there?
__________________ 2004 CCLB LB7 3" Leveling Keys with 2" Blocks in the Rear ProComp RS 9000 Shocks 18" Black XD Crank with 305/70R18 Dick Cepek FC II EFI Live Idaho Rob DSP through Edge Insight Profab Downpipe 4" MBRP straight pipe w/ 5" tip Soon to Come: 30% or 40% Overs AirDog II 165 |
| DuramaxForum Veteran Join Date: Feb 2011 Location: Granbury, Tx.
__________________ 05 lly, bills 5" intake with lbz mouthpiece, ppe manifolds up pipes, 6"rcd custom lift, three inch drop shackles, torsion bolts outs, nitto 420's 305/50/20, ppe tie rod sleeves, airdog II 165 lift pump, egr delete, pcv reroute, 4" turbo back straight pipe, stage 5 tranny from alligator performance ,68 mm turbo from Danville, arp head studs, efilive |
| Senior Member Join Date: Oct 2012 Location: Everywhere
| On my to do list this Christmas vacation too
__________________ Purchased 11/15/12: 2004 LB7 CCSB, ATS 4000 turbo, upgraded injectors, Diamond Eye 4 inch turbo back exhaust, H2's on 315/70/17's, Ranch hand front bumper. EFI LIVE by Kory Willis Purchased parts awaiting install: Moog problem solver lower ball joints, Moog pitman and idler arm, AD 165 ![]() Special thanks to: Brent@LDS, mrmanners@Synthetic Motorsports, and Kory Willis@PPEI. DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource Jesus loves YOU, Have you asked Him to be your Savior yet? |
| Junior Member Join Date: Oct 2012 Location: Nebraska
| you should get cognito upper control arms they have balljoints and bushings in them and they are specially designed for lifted applications |
| Junior Member Join Date: Oct 2011
| control arm bushings Quote:
| I have considered cognito upper control arms but they are a bit pricey. Are they really worth it? Ive also looked into the Moog upper control arm with extra 2 degrees of camber adjustment. Im leaning towards doing the Moog with extra 2 degrees of adjustment. How do those stack up with the Cognitos? Also does Moog make a direct bolt in lower control arm with ball joints and bushings already in it? I cant find one.
| It rides a little rougher with the new keys but its only been a week and I'm already use to it.
