| DuramaxForum n00b Join Date: Sep 2012
| LB7 Cranks but wont start Truck seemed to be running fine. thought it may be down on power but couldnt really tell. Thought it was just in my head. Went in the pizza place for 5 minutes and came back out. It would just crank and crank and crank. So being stranded I sprayed some wd40 in the air filter and it started up and will run all day. May be down on power but not too terrible. Sometimes when i shut it of it will fire right back up. Most of the time it just cranks. Any ideas. I definately think im getting air somewhere. IF not getting air in the lines what else could it be. ![]() Thanks |
| All In Join Date: Jan 2011 Location: West Texas
| More than likely with it being an lb7 it'll be bad injectors. What happens the bad injectors let fuel through when they shouldn't and it's able to build enough rail pressure while cranking. When you spray it it cranks fast enough to fire. Once it's running it's turns fast enough to maintain rail pressure. Get your balance rates checked.
__________________ cc/sb lb7, lowered, cut & delipped, lbz rods, keyed, balanced, ati, so cal flex, studded, +40 nozzles, going 360/480 from SDP Last edited by Meshanic; 12-12-2012 at 08:31 PM. |
| ahh dont tell me that.. Just kidding thanks for the input. COULD it just be its sucking air somewhere? |
| Junior Member Join Date: Oct 2012 Location: Go Bucks!
| I would suspect it's sucking air. Is the primer soft? Does bleeding and priming help? If so, I'd suspect a leaking fuel filter head. Nothing an o-ring kit wouldn't fix.
__________________ '03 CCLB 2500HD 4x4 SLT LB7/Allison. 263k miles. broken CB, broken strobe, B&W turnover goose. Fencepost inspired body mods '03 CCLB 3500HD DRW LB7/Allison 197k miles '97 6.5TD SMURF Blue (SOLD) Ether is for pulling tractors! |
| i can pump it up and get it semi hard.... sounds bad, but when i walk around and crank it and go back to check it, its soft again. Last night i got it real hard and cranked for about 30 seconds and it started. |
| Junior Member Join Date: Jan 2012 Location: Morgantown, WV
| your getting air in the fuel it shouldn't get soft again. check the filter to make sure it is tight. worse comes to worse use an air compressor to blow down the fuel line from the filter head to see if there is a leak anywhere. Do smell diesel around the truck. I would check fuel lines and fuel head for leaks.
__________________ Andy Work Trucks: 2003 Chevy 2500hd lb7 WT sclb stock 2006 Chevy 3500 srw lbz LT3 eclb stock LBZ soon Last edited by aturking; 12-12-2012 at 08:57 PM. |
| If it's losing prime it might just need the fuel filter head orings replaced.
__________________ cc/sb lb7, lowered, cut & delipped, lbz rods, keyed, balanced, ati, so cal flex, studded, +40 nozzles, going 360/480 from SDP |
| ok well thats good news, hopefully i can get this figured out. Have you heard of getting rid of the stock filter housing completely and just running an air dog. I have one ordered it should be here friday. |
| Yep a bunch of people do that. The air dog filters fine.
| is it pretty easy? Im still pretty new to diesels. They scare me a little bit. And yes this morning i could smell fuel but cant find where its coming from. Im sure its from the filter housing. Just praying I can bypass that with the air dog and it fires right up. |
