Power steering pump - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 12-13-2012, 09:59 AM Thread Starter
Power steering pump
Just refilled the power steering fluid on my truck but the wheel is still hard to turn and it makes a wining noise on sharp corners
Floridamax17 is offline
post #2 of 10 (permalink) Old 12-13-2012, 10:05 AM
NastyMAX's Avatar
maybe pumps going out or need a good flush..... how's your breaking
Sent from my Moto 2500 Razormaxx
using my bean flickers
02 ccsb LB7 stright pipe 6in lift 33's
intake baffle delete 8k HID'S and some emergency lights
NastyMAX is offline
post #3 of 10 (permalink) Old 12-13-2012, 10:06 AM
Few things will help that:
1) Flush the hydrobost / Power Steering system with synthetic fluid (amsoil, redline, etc)
2) Add a power steering cooler (GM P/N 10385584)
3) 3/8" magnafine filter between cooler and P/S pump return
MTL_Dmax is offline
post #4 of 10 (permalink) Old 12-13-2012, 02:12 PM Thread Starter
The brakes are a little soft I topped off the power steering about two days ago it's still full so no leaks but a pain in the but to turn
post #5 of 10 (permalink) Old 12-13-2012, 04:57 PM
Do the items I suggested above and if it still doesn't improve your P/S pump is probably toast.
MTL_Dmax is offline
post #6 of 10 (permalink) Old 12-13-2012, 05:42 PM Thread Starter
I got it working now my dad did some research and found that there's a valve in the pump that can stick. So I went and bought some of that Lucas power steering conditioner. Its smooth as butter now
post #7 of 10 (permalink) Old 12-13-2012, 06:05 PM
The pressure valve sticks because the fluid overheats as mentioned above.
MTL_Dmax is offline
post #8 of 10 (permalink) Old 12-14-2012, 05:38 AM Thread Starter
And it's blowing fluid again
post #9 of 10 (permalink) Old 12-14-2012, 05:58 AM
........because it's overheating.
MTL_Dmax is offline
post #10 of 10 (permalink) Old 12-14-2012, 05:23 PM
I used Lucas as well, it improved it greatly and the slight noise I had is gone.
walterd is offline
