02 lb7 w/t cruise control - Chevy and GMC Duramax Diesel Forum
Old 12-25-2012, 12:11 PM   eBay Motors  #1 (permalink)
cummins351's Avatar
This truck did not come with cruise so i was wondering if there is an easy way to hook it up?
Sent from my DROID3 using AutoGuide.Com Free App
2001 ecsb lb7 bone stock
cummins351 is offline   Reply With Quote
Old 12-25-2012, 03:14 PM   eBay Motors  #2 (permalink)
2trout's Avatar
are you sure you don't have cruise??....I thought that was a standard fit these days!
'MONGO' '02 2500HD 4X4 CC/SB
Built transmission - GOS Performance; Suncoast 6 speed conversion
4" Exhaust
aFe cold air intake
BatMoWheel (stock turbo)
ProFlow Air Horn, MBRP Downpipe
Edge Insight CTS - EGT Probe; EFILive via CTS - Idaho Rob
AirDog II DF-165
Firestone Ride Rite air helper springs
Bilstein shockers
Fumoto Oil Valve
2trout is offline   Reply With Quote
Old 12-25-2012, 03:16 PM   eBay Motors  #3 (permalink)
cummins351's Avatar
Nope its not on the column lever like my 01
Old 12-25-2012, 03:18 PM   eBay Motors  #4 (permalink)
2trout's Avatar
huh!.....bizarre!....not sure how you'd go with fitting an OEM unit, if the wiring harness is present, then it may not be a big deal to fit an OEM unit, I would not know what control modules you'll need to get though, otherwise, an aftermarket unit might do the job...
4" Exhaust
aFe cold air intake
AirDog II DF-165
Bilstein shockers
Fumoto Oil Valve
Old 12-25-2012, 03:20 PM   eBay Motors  #5 (permalink)
cummins351's Avatar
Maybe just the multi switch
Old 12-25-2012, 03:21 PM   eBay Motors  #6 (permalink)
2trout's Avatar
could well be 'plug 'n play', that would be the easiest for sure!, maybe other members here can chime in, otherwise, check this out Silverado / Sierra '95 - '02
4" Exhaust
aFe cold air intake
AirDog II DF-165
Bilstein shockers
Fumoto Oil Valve
Old 12-25-2012, 03:53 PM   eBay Motors  #7 (permalink)
2trout's Avatar
came across this diagram whilst looking for something else, this will give you an idea whats needed http://www.gmtruckcentral.com/wiring...l%20Curcit.pdf
4" Exhaust
aFe cold air intake
AirDog II DF-165
Bilstein shockers
Fumoto Oil Valve
Old 12-25-2012, 05:40 PM   eBay Motors  #8 (permalink)
IGOU's Avatar
I'm in the same boat. When you get this figured out, please do a build thread.
Robert,
'03 Silverado, CCSB, 4WD 2500 HD,
20% injectors, ADII 165, K&N drop-in air filter,
buckstop bumper, w/ Warn powerplant winch, and PIAA fogs.
Rear airbags.
'02 CCLB 2WD 2500HD
white, stock w/t w/ ZF-6
(new to me) (loving this ZF-6!)
IGOU is offline   Reply With Quote
