Cracked head - Chevy and GMC Duramax Diesel Forum
post #1 of 34 (permalink) Old 12-25-2012, 08:59 PM Thread Starter
Ezkieler850's Avatar
Cracked head
Hello, this is my first, but I've been hiding in the shadow for a couple weeks now. I've been digging through the archives to give myself a heads up before tackling this project.
Anyways, I bought an 01 lb7 with 186,000 miles that was blowing white smoke and little bubbles forming in the overflow tank (it gets worse when warmed up). If there is coolant in the oil it's not obvious. The previous owner gave up after putting head gaskets on it and still had the same problem.
I pulled out all the glow plugs and pressure tested it. Coolant came out of the # 3 glow plug hole after 20-30 minutes. Then I removed the injector cup, cleaned off all the old lock tite very well, put lock tite on, instantly reinstalled cup, waited 32 hrs, filled with coolant, pressure tested and coolant came out the # 3 glow plug hole again after 20-30 minutes.
I pulled off the head and the gasket, the head and block showed no obvious traces of a coolant to cylinder leak. When looked at the head closer this is what I found..............
Does this look like a crack? Has anyone ever seen this before? It looks like a crack consisting of pin holes. I'm going to try and get a magnifying glass tomorrow, to get a better look.
Sorry for the long post, I just wanted to explain it correctly.
Ezkieler850 is offline
post #2 of 34 (permalink) Old 12-26-2012, 02:55 AM
mjonesjr's Avatar
Have the head fluxed. That will tell if there is a crack there.
~ 2001 Silverado 2500HD CCSB 4x4 Duramax ~
443 RWHP & 842 RWTQ
- S&B Intake - Diamond Eye 4" Stainless Exhaust - PPE Boost Valve - AirDog II 165 - EFI Live by Danville Performance - Edge CTS Insight - Longhorn Fab Traction Bars -
mjonesjr is offline
post #3 of 34 (permalink) Old 12-26-2012, 10:32 AM
duratothemax's Avatar
Explain to me how you magnaflux an aluminum head.....
ben
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #4 of 34 (permalink) Old 12-26-2012, 12:18 PM
mike diesel's Avatar
ben
05 Dmax/Allison
10.86@133
mike diesel is offline
post #5 of 34 (permalink) Old 12-26-2012, 12:58 PM
have the head preasure tested . but if it was me i would replace the head
05 3500 ccdrw lly, complete lbz banks ram-air intake set-up with with super scoope, egr deleted profab intake elbow , diamond eye 4' duals , diamond eye down pipe and no kitty efi by full throttle customs , edge insight cts for gauges ,lbz mp. and fuildamper .pcv reroute,right and left side boost tubes, banks techi cooler ppe ported fitting , afe rear diff cover magtec trans pan ,does it ever end airdog 2 165 bd manifold, merchant transfercase brace and rub kit , transgo jr, custom convertor . earls 82510aerl for trans cooler ,hellwig bigwig rear sway bar , fleece tap shifter
www.alligatorperformance.com
www.merchant-automotive.com
www.madjacksynthics.com
happyduramax is offline
post #6 of 34 (permalink) Old 12-26-2012, 01:16 PM
Administrator
jc1843's Avatar
Look how clean the head is on that cylinder, compared with the other cylinders-- looks like it was steamed cleaned-- because it was. You need a new head.
jc1843 is offline
post #7 of 34 (permalink) Old 12-26-2012, 01:22 PM
dirthand1's Avatar
ha ha ha that was pretty funny .how do you magnaflux an aluminum head????? answer is you cant the head has to be cast iron for the process to work but they do have spray dyes for aluminum to see where all the cracks are.
dirthand1 is offline
post #8 of 34 (permalink) Old 12-26-2012, 02:15 PM
JUST TROLLING AROUND
vinnie gillotti's Avatar
Send a message via Yahoo to vinnie gillotti
ben play nice.
vinnie gillotti is offline
post #9 of 34 (permalink) Old 12-26-2012, 04:17 PM Thread Starter
I actually cleaned the head up with a non scratch scotch brite pad to get a better look at the crack/corrosion. I dropped it off at the machine shop to have it pressure tested, hopefully I'll know tomorrow. I'm probably going to get a new head either way, but I would feel alot better knowing it was bad for sure.
post #10 of 34 (permalink) Old 12-26-2012, 04:23 PM
If you do get a new/used head, just make sure it matches your other head. LB7's had two different types heads depending on whether they were california emissions or federal emissions.
06 audi S4, V8/6spd
