My truck turns over but will not start - Chevy and GMC Duramax Diesel Forum
Old 12-30-2012, 02:00 PM   eBay Motors  #1 (permalink)
My 03 Dmax problem started with my gauges not working intermittantly and then one day the didn't work at all all day.that evening when I went to start it, it cranked a little slow but it started. so I got on the freeway and realized my lights were dim and then the truck went into limp mode and wouldn't go over about 40 mph.so by the time I got off the next exit when I went to turn the corner the tranny did a couple of funny clunks and quit working. by then the engine was barely running so I shut it off. Batteries were totally dead by then. I had it towed home, disconnected the batteries and charged them. Now all it does is turn over and will not start.Gauges still don't work but engine turns over just fine. all other lights on dash work and I primed the pump so it seems to have fuel. The only code it gives me is P0380 for glow plug circuit A malfunction. but that doesn't explain the gauges not working and the batteries going dead. I also had the alternator tested and its good. What to do next ? Thanks.
CHEVY NOMAD is offline   Reply With Quote
Old 12-30-2012, 02:45 PM   eBay Motors  #2 (permalink)
rd05lly's Avatar
Have the batteries tested.
05 CCSB EFI Live by Kory Willis
76 Dodge Charger SE
https://syntheticmotorsports.com/
rd05lly is offline   Reply With Quote
Old 12-30-2012, 03:25 PM   eBay Motors  #3 (permalink)
Batteries are fine, It cranks over just fine. just won't start.
Old 01-04-2013, 08:12 AM   eBay Motors  #4 (permalink)
Chadly8301's Avatar
Do you have access to a scan tool to monitor fuel rail pressure sensor to see what the pressure is coming from the inj pump to the rail?
2007.5 CCSB LTZ 4wd Loaded - Edge Race Evo Box Tuner - 4in. MBRP turbo back - 15% on all windows - GM accessory headrest DVD - GM factory Nav... Many hopes and dreams to come... Just a little somethin to tow the boat
Chadly8301 is offline   Reply With Quote
Old 01-04-2013, 09:32 AM   eBay Motors  #5 (permalink)
bigjohn's Avatar
You would think it would be the alternator if you we're losing charge where everything going dead.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
bigjohn is offline   Reply With Quote
Old 01-04-2013, 01:03 PM   eBay Motors  #6 (permalink)
Chadly8301's Avatar
Yeah i would definatly agree with ya. If they died while driving it for sure points at a charging issue. But if you have the batterys fully charged and it still doesn't start then it's got something else going on...
Old 01-04-2013, 04:26 PM   eBay Motors  #7 (permalink)
ippielb's Avatar
While your at it check if your primer button on the top of your fuel filter is hard to press. if its soft bleed some air out. Could be half of problem. Cranked it over so much to get it started drained your battery a bit. Just a thought.
2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
NADP Race Transmission & NAPC Built Transfer Case
AFE Stage 2 Intake with Snow Performance Methanol Injection
FASS 150gph Titanium Series Pump
EFI Live
PPE Race Valve & PPE Bored Fuel Rail Fitting
Yukon Grizzly Locker with Mag-Hytec Cover & Traction Bars
Leveling kit & 34.5" Hankook RT03 18" XD Rims
HID's all around LED taillights and 3rd brake light
Pioneer Double-DIN Touchscreen Navigation with Two 10" Subs under rear seat
Autometer GM Match Fuel Pressure, Boost, and Pyro Gauges
ippielb is offline   Reply With Quote
Old 01-06-2013, 08:06 AM   eBay Motors  #8 (permalink)
Super Moderator
jc1843's Avatar
Moving to LB7 for more support
Old 01-06-2013, 05:59 PM   eBay Motors  #9 (permalink)
lb7dirtymax01's Avatar
Whens the last time your fuel filter was replaced? These trucks hate when you dont replace that. If it were mine I would get two 5 gallon cans of diesel, pour them in the tank, and change the fuel filter. Just my $0.02
lb7dirtymax01 is offline   Reply With Quote
