Factory High Idle Enable - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 01-06-2013, 08:02 AM Thread Starter
mjonesjr's Avatar
I did the high idle modification yesterday by tapping into the Green/White on the brake pedal and putting the ECM pin in. I'm not a fan of how that if I leave my cruise control on and then go to park the high idle kicks in.
I'm curious as to how the factory wired option sends the power to ECM pin 71. There has to be a factory switch to enable it.
Does anyone know where the factory enable switch is located and if it can be bought?
~ 2001 Silverado 2500HD CCSB 4x4 Duramax ~
443 RWHP & 842 RWTQ
- S&B Intake - Diamond Eye 4" Stainless Exhaust - PPE Boost Valve - AirDog II 165 - EFI Live by Danville Performance - Edge CTS Insight - Longhorn Fab Traction Bars -
mjonesjr is offline
post #2 of 3 (permalink) Old 01-06-2013, 04:53 PM
dirty_maxx's Avatar
put a switch in between the brake wire and the ecm so you can turn it on and off.
2004 chevy 2500hd eclb, lly, 6spd manual, lift, rims and tires, afe intake, mouth piece and intercooler pipes. mbrp downpipe, mbrp 4" exhaust, pcv reroute, airdog 2 165, nicktane cat filter adapter, cognito and kryptonite front end, autometer cobalt gauges, valair dual disc clutch, fluidampr, efi live
dirty_maxx is offline
post #3 of 3 (permalink) Old 01-06-2013, 04:55 PM Thread Starter
mjonesjr's Avatar
I'm probably going to get the PPE High Idle kit. It looks close to factory. I like for things to look factory.
443 RWHP & 842 RWTQ
mjonesjr is offline
