| Junior Member | Burning oil??? I heard a loud rattle the other day when I cranked my truck. I checked the oil and it was not even showing on the dipstick. I added oil immediatly and it ran fine. No smoke, no oil smell, balance rates are in spec as the injectors were replaced 5k miles ago. What could this be? Where is my oil going? No oil on the ground either.
__________________ Black 03 GMC Sierra CCSB PPE standard level 3,Tow Mirrors, muffler delete,Tie Rod Sleeves, Kennedy's Airbox Mod,resonator delete,All on headlight mod,8k Hid Lows/Hi/Fogs,PPE Boost Increase valve, Black Kobalt Toolbox, Blacked out lights,blacked out bumpers, JVC double din radio, Leveled out on 295/70 BFG All Terrains |
| Junior Member | anyone??
| Senior Member Join Date: Jan 2012 Location: edmond ok and nw ks
| You can burn quite a bit of oil without noticeable smoke. Sent from my iPhone using AutoGuide.com App
__________________ Curt 05 GMC ccsb slt 4x4 efi live 3"dp 5"straight pipe built trans airdog blocked rerouted lbz mp power steering 95 dodge eclb cummins 4x4 5sp slt 90 F-250 rclb 7.3 4x4 |
| how many miles between oil changes?
| Junior Member | Usually about 5-7,000
| Junior Member | Also found the rattle. Exhaust hanger broke loose and was hitting side of tranny housing
| its not pumping your oil into the radiator is it? through the oil cooler?
| Junior Member | How would I check that?
| you can check yur reservoir.. but if u were real worried about that drain all the antifreeze out when its hot, if there is oil in there it will be thin enough to come out pretty easy.. it may not be that, your truck could just burn that much oil between changes
| Junior Member Join Date: Aug 2010
| try adding a bottle of lucas oil stabilizer every change and shorten the span to less than 5,000 miles. might help a little
__________________ ![]() 01 chevy Lb7 dirty D Ext cab sbfull 4" exhaust to 6" tip afe stage 2 cold air ported turbo inlet ppe boost valve dual auto meter ultra lite gauges |
