Junkyard shortblock... junkyard turbo... LOW oil pressure after warmed up? - Chevy and GMC Duramax Diesel Forum
Old 01-16-2013, 06:26 PM   eBay Motors  #1 (permalink)
I dont wanna make this post to long because I get off track to easy so Ill try and make it short and to the point.
Truck comes in smoking its azz off and obviously running like crap...
Had injectors tested and 2 were supposedly bad so the owner wanted to go ahead and replace them all.
Got them all in and still smoking and running horrible no change at all.
So we do a compression test and find #7 cylinder down on compression.
Piston had melted and destroyed the bore..
We found a good used short block (or thats what they said) and I got everything buttoned back up and rans good but still smoking like some little man was under the hood dumping oil in the intake!.. but it wasnt running bad so I was sure the turbo was shot and sure enough the thing had about 1/2" of play on the exhaust side pouring oil straight into the exhaust
So then I got a junkyard turbo (looked great and clean) and got everything back together and took a deep breath.... It starts right up and runs awsome once all the oil residue gets burnt out the exhaust with a couple of wot pulls to about 80mph...
BUT when I pull back in the shop the low oil pressure light comes on and is in the red it did not do this before the junkyard turbo was swapped on. I checked it with a manual guage and it reads right around 8-10psi at idle and fluctuates abuot 2psi even when the truck is remaining at the same idle rpm
Im lost on this and dont wanna tear this engine back out...
If anyone has any info for me that would be great!!!!
Could a turbo cause low oil pressure once the engine warms up ONLY?
If its cold when I crank it, its around 60psi at idle but once its at operating temp it drops back to about 10psi or so
The oil does not smell like fuel and is still as clear as when I put it in..
Ive got to be missing something, this is my first duramax and so far it hasnt been a good experience
posduramax is offline   Reply With Quote
Old 01-16-2013, 07:01 PM   eBay Motors  #2 (permalink)
TakeEm's Avatar
The turbo couldn't cause low oil pressure period unless it was pouring out one of the seals. You would obviously see if there was an oil leaking issue.
You have something else going on.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is online now   Reply With Quote
Old 01-16-2013, 07:03 PM   eBay Motors  #3 (permalink)
TakeEm's Avatar
What engine is this?
Caleb 22
Old 01-16-2013, 07:13 PM   eBay Motors  #4 (permalink)
Lb7
Old 01-16-2013, 07:27 PM   eBay Motors  #5 (permalink)
thats what I thought, the oil pressure was fine before the turbo swap but that doesnt mean something didnt go wrong when I test drove it after I got the newer turbo on. My boss just seems to be sure that something is wrong with the new turbo... lol
Old 01-16-2013, 07:37 PM   eBay Motors  #6 (permalink)
boostnlb7's Avatar
why is it idling at 8-10 psi? and an oil pressure sending unit or sensor could not be reading right and causing it to say low oil psi..if its sending a bad reading then the computer thinks its got low oil psi.. im still curious to know why your boost is pressured at an idle.. where did u take the reading from?
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 01-16-2013, 07:47 PM   eBay Motors  #7 (permalink)
clinebarger's Avatar
I know this truck is pissing you off (Im a Mechanic also).....But you could have picked a better username
Your oil pressure is low. 14psi at hot idle is minimum. On a healthy Duramax I like to see 25psi.
What oil are you using?
Plugged oil filter?
Do a "paper towel test" on the oil. Fuel will migrate away from the oil.
Other possibilities.....
◦Malfunctioning oil bypass valve
◦Oil pump worn
◦Oil pump-to-engine block bolts loose
◦Oil pump O-ring damaged or missing
◦Oil pump to oil pump tube gasket missing or damaged
◦Oil pump tube restricted or cracked
◦Oil cooler restrictions
◦Oil cooler O-rings damaged or missing
◦Excessive bearing clearances
◦Cracked, porous or restricted oil galleys
◦Oil gallery plugs missing or incorrectly installed
◦Damaged or missing oil spray cooling nozzles
2006 Chevy LT3 CCSB 2500HD LBZ/Allison
AirDog 100, Nicktane CAT filter head, Billet bleed screw, Blocked EGR, Bilstein, AAM alum. diff cover, Michelin M/S2.
1985 Chevy C20 Suburban with a '04 5.3L/4L60E
K&N intake tube w/ stock box, Built trans, Michelin A/S.
clinebarger is offline   Reply With Quote
Old 01-16-2013, 08:07 PM   eBay Motors  #8 (permalink)
I thought the username was appropriate at the time lol...
Mobile Delvac 15w40 I believe
I already changed the filter (again) and it didnt help
I will try the paper towel test tomarow
I know there is no way to drop the pan without pulling the engine, but can you possibly get to the oil pump with the engine still in the truck? Probly a stupid question....
Would any of those items on your list cause the pressure to fluctuate? At a constant idle the pressure was moving up and down about 2 or 3psi.
Maybe I just need some thicker oil and tell the guy to go trade it asap~! lol jk
Old 01-16-2013, 08:12 PM   eBay Motors  #9 (permalink)
boostnlb7's Avatar
hahaha pawn it off eh.. you have to pull pan to get to oil pump..
Old 01-16-2013, 08:14 PM   eBay Motors  #10 (permalink)
boostnlb7's Avatar
i just read back...im such a freakin retard!! sorry guys im out.. time for bed.. disregard my posts
