| Junior Member Join Date: Jun 2011 Location: Johnstown Pa
| All LB7 owners need to do this!! I never heard of this problem until it happened to me.. I was driving down the highway, not loaded with the cruise at 70 when a vibration started all of the sudden. So I slowed down until the vibration went away and drove the last mile to my destination. When I got out of the truck I found all of my tranny fluid pouring out on the ground. I had one of the 4 bearings on a u-joint go bad and the small amount of vibration broke the rear housing on the transmission. It it almost $700 dollars in parts, so: Have you replaced your u-joints yet? If not it may be time to replace them or it is time for you to get a rear housing brace like ATP and Merchant Auto sells for around $160-$190 Learn from my experience, and spend the money now to fix it before you get the big bill. :
__________________ '03 2500 HD : Banks: 6-Gun Power PDA, Big head waste gait, air intake lid, tie rod sleeves, 4x4 brackets, Nitto 305/70/16, Silverdine 5" Duals |
| Junior Member Join Date: Feb 2011 Location: Pendleton
| Not if ya got a zf6!
__________________ 2001 RC/lb lb7 zf6 EFI 120hp tune. 5" exhaust, Custom Boost Valve Holly Lift pump, Dual Filtration system,Custom Traction Bars 16" method race wheels w/ BFG allterrains Blad tires and clutch slippage thanks to sheid Diesel extravaganza 2012 |
| Junior Member Join Date: Apr 2012
| U joints are always over looked until there is a vibe. I have some on the bench waiting to go in. The Delco's are priced well and made in the USA. |
| Yeah it wasn't even a bad vib and I slowed down pretty fast so I can't believe it broke that easy! Sent from my iPhone using AutoGuide.com Free App
| DuramaxForum Veteran Join Date: Feb 2010 Location: College Station, Tx
| Aluminum isn't the toughest metal haha. If you think how fast that thing is spinning I can see where the forces came from. How many miles on the u-joints? Sent from my iPhone using AutoGuide.com App
__________________ -Austin- Fightin' Texas Aggie 2001 LB7 2500HD CC/SB 2WD 5" Flo~Pro Straight w/ 7" Tip| ProFab Intake Horn |Spectre Stage-2 CAI | EFI Live w/ DSP-5 | PPE Stage IV Transmission | ProFab Downpipe | PPE Boost Valve | Holley Black Lift Pump | Intake Heater Delete | GlowShift Guages (Boost, Pyro, & Fuel Pressure) | 3" Drop Shackles | 18x9 Falken ORC 952's | Nitto Terra Grapplers 285/65/r18 | Kenwood Deck | 2 12" Kenwood Subs on 2200watts | 4 6-1/2" Pioneers (Doors) on 350watts | JML 6000k HID Lo-Hi/Fog | Herculiner Bedliner | Westin Side Steps | Ranch Hand Full Front and Rear Bumper Replacement. 546hp & 1025 ft/lbs at Lone Star Dyno, Spring Branch Tx. |
| True but u joints used to go bad all the time and nothing else broke normally. I bought the truck with 135000 on it and don't know if they were ever changed. I know u joints wear out but just the fact that only one bearing was bad of the 8 was a little redic. Sent from my iPhone using AutoGuide.com Free App
| What miles were you at when they popped? Got 200,000 on my original ones... You're scaring me haha Sent from my iPhone using AutoGuide.com App
| front u joint or rear? on the rear driveshaft
