What are these markings in the cylinders? - Chevy and GMC Duramax Diesel Forum
Old 01-17-2013, 10:34 AM   eBay Motors  #1 (permalink)
elliottw's Avatar
I'm rebuilding an LB7 with 288k miles on it. He said it had a knock and it went away when he cut out cylinder number 2. All the rod and main bearings looked good for an engine with close to 300k on it. So we pulled the heads off and it has these black markings, they look uniform and they are in all the cylinders. Is it spray pattern from the injectors? We're thinking it has a knock from the injectors, he got new tips on them last year, I'm sure at one point the whole injectors were replaced as it has a lot of miles. Can you guys give me any input on these markings though? Thanks
2009 CCSB LMM-EFI live with DSP5 by Idaho Rob. Some other stuff
Props to ADP ATP MPF And Husker Diesel
elliottw is offline   Reply With Quote
Old 01-17-2013, 02:31 PM   eBay Motors  #2 (permalink)
KB3MMX's Avatar
HAHA, nobody answered this yet ?????? !!!
Anyway, it's called Duramax "Leopard Spots".. It's a GOOD thing.
In the manufacture of the Duramax engine, a electronic inductive heating process is used to harden the upper portion of the cylinders...making them VERY strong.
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
Old 01-17-2013, 03:02 PM   eBay Motors  #3 (permalink)
elliottw's Avatar
Awesome dude! Thanks, we were scratching our heads as to what they were lol
Old 01-17-2013, 06:11 PM   eBay Motors  #4 (permalink)
I am in the middle of changing my headgaskets and noticed these same marks. Now I know what they are.
Bluemm is offline   Reply With Quote
